oakwoodforge Posted November 9, 2006 Share Posted November 9, 2006 This is a mix of 1084 & 1095 powder , welded in a "can " Jens Quote Link to comment Share on other sites More sharing options...
Candidquality Posted November 9, 2006 Share Posted November 9, 2006 Actually seeing that on the piece of wood made me think. Have you ever tried to reproduce a wood pattern using the powdered steels? Seems that it would take a little forethought, but would be possible. Nice blade btw. Quote Link to comment Share on other sites More sharing options...
Woody Posted November 9, 2006 Share Posted November 9, 2006 To make a wood grain pattern, assemble a billet of about 25 layers, bandsaw blade and steel banding works well and gives a nice contrast. Forge the billet out to about 1 inch wide and 1/4 inch thick then taper both ends. Now start rolling the billet up welding it as you go like a jelly roll. when you have finished it, you should have a cylinder about 1 1/2 inch in dia and one inch high. Now hammer it down from the end and forge it into a blade. The link will take you to a blade with that pattern. WoodyWoodgrain or Jelly Roll Pattern - Blacksmith Photo Gallery Quote Link to comment Share on other sites More sharing options...
oakwoodforge Posted November 10, 2006 Author Share Posted November 10, 2006 Here is how I did it : I cut a 6 inch long chunk of 3/4 " square steel tube , then made a 1/2 " cut at each corner, so I can fold the "flaps" like a card board box. http://www.easypics.us/pics/Powdersteel.1.JPG I used 1095 & 1084 Powder this time, but I have also used O-1 Mill/ drill chips. ( got a good buddy at a machine shop ) I weld the flaps together on one end then start filling a scoop at a time packing and tamping often, I also put a small pinch of sawdust at each end. Once its full I pound the top flaps together and weld a handle on. Here it is ready to be forge welded. http://www.easypics.us/pics/Powdersteel.5.JPG And here it is soaking slowly up to a welding heat. The fist few welding heats were weird , kinda felt like hammering on a cooked noodle. About the 3rd heat it just got solid all the sudden and started acting like one bar of steel. Quote Link to comment Share on other sites More sharing options...
Candidquality Posted November 10, 2006 Share Posted November 10, 2006 Thanks for showing us how you did that. Very interesting. Definitely going to have to get off my rear and try it. looks too interesting. one question though. is it hard to remove the square tube after the welding process? and if so, why not use something like stainless foil as a barrier inside? Quote Link to comment Share on other sites More sharing options...
julian Posted November 10, 2006 Share Posted November 10, 2006 Nice work Jens! That stuff takes a lot of work, good job on the blade :) Quote Link to comment Share on other sites More sharing options...
mike-hr Posted November 10, 2006 Share Posted November 10, 2006 Thanks for the pics on that. I'm interested also on how hard it was to remove the 'can'. Quote Link to comment Share on other sites More sharing options...
Rantalin Posted November 10, 2006 Share Posted November 10, 2006 Could be wrong on this, but the way I pictured the procedure, the "can" actually becomes part of the blade, and later gets ground away to reveal the pattern. Quote Link to comment Share on other sites More sharing options...
oakwoodforge Posted November 10, 2006 Author Share Posted November 10, 2006 The thin wall steel "can" was partly lost to scale, But I attacked the remains of the "can" with my trusty 4.5 inch angle grinder. It took 5 min tops, of grinding to remove it before I forged it to the final shape. Jens Quote Link to comment Share on other sites More sharing options...
elfshadow14 Posted November 10, 2006 Share Posted November 10, 2006 Hey I love japanese blades and you keep to there style very well.Great tanto. BTW have you ever made a katana or wakizashi? Quote Link to comment Share on other sites More sharing options...
mcraigl Posted November 15, 2006 Share Posted November 15, 2006 Where the heck did you get all the "powder"? Isn't the stuff from a machine shop awefully contaminated with cutting fluid etc.? Another real nice one Jens. Quote Link to comment Share on other sites More sharing options...
V Posted November 15, 2006 Share Posted November 15, 2006 Saw it at DFogg´s and think it is a great piece!!! must share more pics Quote Link to comment Share on other sites More sharing options...
oakwoodforge Posted November 15, 2006 Author Share Posted November 15, 2006 Kelly Cupples Steel is the place Mcraigl , here is a link Steel Prices Quote Link to comment Share on other sites More sharing options...
oljoe Posted November 15, 2006 Share Posted November 15, 2006 Thanks for posting this Jens. I had no idea that you could get that kind of contrast with steels that were that similar. I have not tried any can stuff yet but after seeing this it is something that I must try.:cool: Oljoe Foster Quote Link to comment Share on other sites More sharing options...
elfshadow14 Posted November 16, 2006 Share Posted November 16, 2006 Hey would someone tell what powdered steel is? Quote Link to comment Share on other sites More sharing options...
oakwoodforge Posted November 16, 2006 Author Share Posted November 16, 2006 elfshadow, powdered steel is just that, Powdered steel. Quote Link to comment Share on other sites More sharing options...
bipolarandy Posted November 16, 2006 Share Posted November 16, 2006 Oak, iv read alot about power sanders making the hamon line muddy. Is this true? Do you use power sanders after the heat treat? -Andrei Quote Link to comment Share on other sites More sharing options...
oakwoodforge Posted November 16, 2006 Author Share Posted November 16, 2006 Andy,to clarify this blade was through hardened, not clay coated, what you see in the blade is the contrast in the different steels. To answer your question though: I profile and rough grind with 80,120 and 220 grit on the belt grinder then finish with sandpaper & stones. Trying to power finish like with a high speed buffing wheel will smear and obscure a hamon. But it wont ruin it, as it is a structure IN the steel not a surface treatment, so you could go back to stones an paper to bring it back. I'm sure you have seen some of Howard Clark's blades, he does the rough work on a belt grinder too, it sure dosen't play funny buggers with his hamons, they're sweet! Keep hammering Jens Quote Link to comment Share on other sites More sharing options...
trying-it Posted February 24, 2008 Share Posted February 24, 2008 Jens I do get busy here occasionally too!!!! And you know I just love powdered metal.....LOLa 4" diameter can ready for the forge - Blacksmith Photo GalleryNeeds just a little more cooking time - Blacksmith Photo GalleryI need a striker or two now, but no such luck as usual - Blacksmith Photo GalleryI will eventually beat this 4" can into submission too - Blacksmith Photo Gallery Quote Link to comment Share on other sites More sharing options...
Feukair Posted February 25, 2008 Share Posted February 25, 2008 Awsome work, amazing... Quote Link to comment Share on other sites More sharing options...
oakwoodforge Posted February 26, 2008 Author Share Posted February 26, 2008 Lookin Good Stan , I cant wait to see what she looks like! Prost ! Jens Quote Link to comment Share on other sites More sharing options...
