FieryFurnace Posted October 26, 2010 Share Posted October 26, 2010 It seems that here lately I've seen a picture of a 90 degree bending jig. However, I'm not sure where I would have seen such a contraption. My question is, would this be a worth while tool to make and if so, what would it look like? Thoughts??? Link to comment Share on other sites More sharing options...
petere76 Posted October 26, 2010 Share Posted October 26, 2010 Traditional method: Square stock you do freehand over the anvil (half blows) or in the vice. Always at a high heat. Some folks upset the bend prior and others don't Round stock you need the upsetting style (vice) tool so as not to kill the round stock dimension with hammer marks. IMHO, The more diffcult of the two. Some guys half cut the angle at the mark, and use a glut weld (forge or electric) to make up the difference on the missing material, trim, forge and grind to dimension. Not traditional but accurate, fast and effective. if you have a lot of these to get done...learn this technique. Most of the work comes down to how much time is involved. In many case other than strictly traditional endevours, the more time spent on a project the less you make. Figure out your shop rate, material costs, man hours etc and plan accordingly. Yes...time is money. An interesting mantra to keep in mind, Whats the most expensive thing in the world ...ans. "free time". Enjoy. Peter Link to comment Share on other sites More sharing options...
arftist Posted October 26, 2010 Share Posted October 26, 2010 A hossfeld bender is a universal jig which will bend many shapes of stock to many different angles. There is also a competitor which offers a very similar also american made machine for less money. The best would be to find a hossfeld bender used. They are very versatile and can be set up to bend pipe and angle iron also. It is possible to build your own hossfeld bender too. I did, and still use it. I made mine exactly the same as the hossfeld and can use their dies or ones I make myself. Link to comment Share on other sites More sharing options...
Nakedanvil - Grant Sarver Posted October 26, 2010 Share Posted October 26, 2010 What's the material, size, grade etc. Hot, cold? How sharp? 90 degrees can be sharp or any radius including the curvature of the earth!. Link to comment Share on other sites More sharing options...
Please sign in to comment
