4 bar twisted cross
#1
Posted 02 September 2010 - 09:32 PM
#2
Posted 03 September 2010 - 06:45 AM
#3
Posted 03 September 2010 - 07:46 PM
#4
Posted 03 September 2010 - 08:35 PM
#6
Posted 07 September 2010 - 09:36 PM
#7
Posted 08 September 2010 - 12:13 AM
#8
Posted 08 September 2010 - 02:57 AM
#9
Posted 08 September 2010 - 10:15 PM
eric sprado, on 08 September 2010 - 12:13 AM, said:
Here are some pics of a random cut twist cross I make out of 1/2 in sq bar. I have given a bunch away and every one seems to really like them
#10
Posted 27 October 2010 - 11:05 AM
Kinaesthetic learner me. http://bushcraftinfo.blogspot.com/
#11
Posted 27 October 2010 - 11:55 AM
postleg, on 08 September 2010 - 10:15 PM, said:
This is just a humble observation - the top looks to me to be a little long. Maybe it's just the picture angle, I'm not sure. I made some out of 1/2" bar recently too and did a bit of research before I started. What I found is that most consider the optimal proportions to be a 1:3 ratio like this: http://thecrossweb.c...dimensions.htm.
I think those look really, really nice. Well done.
#12
Posted 27 October 2010 - 04:28 PM
I forged a 1/2in sq hole in the middle of the cross bar. I used a sawall to cut the bar. You cut oposite edges random depths then chisle a line on both side of the other two edges. I then heat and twist the cross bar from the hole out reheat ahd twist he other side. I twist the main cross piece up to the point it will go through the cross bar. I assemble the cross and heat then put in the vise and twist the top. The crosses in the pics are some of the first ones I made so the tops are a little long. I have adjusted that on later crosses
#13
Posted 27 October 2010 - 04:41 PM
#14
Posted 27 October 2010 - 09:32 PM
RefinedByFire, on 27 October 2010 - 04:41 PM, said:
This twist is what really got me interested in blacksmithing. I came a cross a youtube video of a guy making a spike knife and used this twist on the handle. It was one of the first things I tried to do and is my favorite twist
#15
Posted 28 October 2010 - 05:34 AM
postleg, on 27 October 2010 - 09:32 PM, said:
A minor point if I may, on the cross member you could make one side a left hand twist, and the other side a right hand twist, this will apparently alter the cross by drawing the overall appearance to lift towards the top or lower the appearance depending on whether the twist lines rise or fall (if that makes sense)
It also indicates more of a hand made item as most machine made twists are just one way
Right and left hand twists are particularly useful for drawing the eye and altering the visual appearances of fireplaces and gates
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
