Using a Harbor Freight Torch
15 replies to this topic
#1 jtcweb
    Junior Member
  • Members
  • Pip
  • 7 posts
  • LocationYpsilanti, MI
Posted 27 August 2010 - 11:26 AM
I picked up on of these to burn weeds. Has anyone tried using it as a burner for a forge.
#2 MattBower
    Senior Member
  • Members
  • 1,848 posts
  • LocationNorthern Virginia
Posted 27 August 2010 - 12:37 PM
I haven't, but it has been done. Tai Goo uses (or has used) one of those things.
http://img.photobuck.../weedburner.jpg
Notice how he has a really reducing atmosphere going. I don't know if maybe that's intentional, but I do suspect weed burners aren't designed to operate well with the kind of back pressure you'll find in a forge. So I don't think it'll be ideal. And you really should have some way to control the choke, in order to control the atmosphere in the forge. But yeah, you can make it work.
#3 edge9001
    Senior Member
  • Members
  • 572 posts
  • Locationchatsworth, GA
Posted 27 August 2010 - 01:09 PM
I've seen several YouTube videos where people hav said those types of burners make a good forge, though I've never tried it.
Tim
Chatsworth, Georgia
[email protected]
Do what thou wilst, yet ye harm none. Blessed Be.
#4 VaughnT
    Senior Member
  • Members
  • 103 posts
  • LocationNorthwest SC
Posted 27 August 2010 - 01:53 PM
I asked the same question some time back and was told that they wouldn't work for knifemaking because they have a very oxidizing flame. Don't know what that means, but I stopped using it for knives b/c the common thought was that it was bad.
It definitely likes to choke out if you get it too close to a wall or the like, due to back pressure.
When reason fails.....
#5 MattBower
    Senior Member
  • Members
  • 1,848 posts
Posted 27 August 2010 - 02:42 PM
That makes some sense, but it's not necessarily an insurmountable problem. I think Tai often throws a little wood in the forge to keep it nice and reducing. Whatever he does must work, because I've rarely if ever seen anyone whose blades look as nice, straight from the forge, as Tai's do. The stuff he does freehand with a hammer and anvil blows me away.
#6 ThomasPowers
    Senior Moment Member; Master Curmudgeon
  • Members
  • 10,183 posts
  • LocationCentral NM
Posted 27 August 2010 - 03:53 PM
"Good Forge" for what? What's an acceptable forge for some things might be quite poor indeed for other things!
Thomas Psychotic Psychobabblonian Powers
#7 HWHII
    Member
  • Members
  • 786 posts
  • LocationTucson, AZ / Bliss, MI
Posted 27 August 2010 - 04:00 PM
Yes I have. I put two of them in a 24" Dia STD Pipe 24" long. They worked great but they really suck the oxygen out of the forge. You have to leave both ends some what open otherwise they will choke them selfs out. I built this forge where I used to work. I needed to preheat some very large trunions made out of 6" solid round and 2" plate. I had to preheat them to 500 degrees before welding them and maintain that heat while welding. It took about 30 min. to bring them up to temp. After the job finished I played with it heating up some larger pipe pieces and it would bring them up to a bright yellow. I wish I would have taken a picture of it. It had a full round door on one end a clam shell door on the other and lined with 2" of Kaowool. I asked if I could have it and they just giggled at me. <_< I use theses weed burners alot in my shop for preheating and heating parts to put patinas on. They are also great for roasting green chiles. ;)
Harold Hilborn
Holy Hammer Ironworks
http://holyhammer.com
"Life can be simple. Don't make it complicated."
#8 dagr8tim
    Advanced Member
  • Members
  • PipPipPip
  • 41 posts
  • LocationColumbus, Oh
Posted 30 September 2010 - 01:12 PM
Not to drag up an dead subject, but I've been playing around with the weed burner idea too.
Could you compensate for the lack of oxygen in the chamber by adding a forced air setup?
I'm looking at the picture posted and wondering if I could build something like that as a starter forge.
#9 MattBower
    Senior Member
  • Members
  • 1,848 posts
Posted 30 September 2010 - 01:57 PM
If you're going to add forced air, you don't need the weed burner in the first place. Forced air is dead simple. Blower, propane bottle and a few standard plumbing parts, and you're done. The weed burner would be superfluous.
#10 Francis Trez Cole
    Senior Member
  • Members
  • 1,088 posts
Posted 02 October 2010 - 01:31 PM
I use my weed burner to light my coal forge works real good
Longfellow:
His brow is wet with honest sweat,
He earns whate'er he can,
And looks the whole world in the face,
For he owes not any man.
#11 Shag Nasty
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 26 January 2011 - 11:01 PM
for the same amount of money you could build a Venturi Burner. I just built a 1" for $20 but I did use a weed burner that I had in the garage for a pressure adjuster and I tried to use the jet but could not get it to work so I used a motorcycle jet that I had on hand.
#12 Phil Krankowski
    Member
  • Members
  • 4,142 posts
  • LocationOhio
Posted 26 January 2011 - 11:25 PM
I was thinking I need a weed burner...for burning the weeds in my driveway!
Other than setting things on fire weed burners are not very helpful. They are designed to have no back pressure, so they work poorly for most anything else.
Phil
Your brain is the most powerful tool you own.
#13 ThomasPowers
  • Members
  • 10,183 posts
Posted 27 January 2011 - 11:24 AM
Sorry I missed this back then: They are NOT sucking the O2 out and choking, by their nature weed burners almost always are too oxidizing and using them to heat metal usually requires them to be retrofitted with some sort of choke to keep from over scaling your work piece.
What they are very sensitive to is back pressure---after all they were designed to work in open air conditions.
And what he said! For the cost of even a HF weedburner you could go by the re-store and buy enough plumbing parts to build several *better* burners for forced air use. Shoot a simple needle valve for gas into a pipe with a couple of bends to mix it works for a forced air burner. Aspirated are much pickier in their construction.
#14 Radeo
    Junior Member
  • Members
  • Pip
  • 5 posts
  • LocationCentral Nebraska, USA
Posted 28 January 2011 - 06:00 AM
Shoot for $20, I built a 3/4" modified side arm burner, and it will take 1/8"x2" to just short of welding temp in open air w/o a forge in just a couple minutes.
#15 pike3e
    Junior Member
  • Members
  • PipPipPip
  • 44 posts
  • LocationBangor Maine
Posted 28 January 2011 - 11:16 AM
Me too. Starts the coal fire very quick.
#16 Klammer
    Member
  • Members
  • PipPip
  • 18 posts
  • LocationVancouver, Canada
Posted 10 February 2011 - 05:25 PM
When I first started knife making I used one of these and some fire bricks to make a simple forge for heat treating. Create a box with fire bricks with an opening in the side for the burner and let it rip. Would get a piece of 1084 up to quench temp in ~2min. I did not experience over oxidation etc. Actually worked fairly well for the cost.
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
