How D all !!! I am in Central Alabama and I am starting to collect all the tools I need to setup my forge. I started with these anvils. I went to get two but picked up the one with the hour glass bottom (Can yall tell me if it is a Hay Budden ??? ) and the horn is complete. It weighs about 220lbs on the scale we put it on. I was told this was a Trenton when I bought it, and I know they had a depression in the bottom, but after reading a bit, Trenton and Arm and Hammer have an oval bottom and the Hay Budden has a hour glass bottom. If it is a Hay Budden it would explain the faint markings I have in one of the PICS that shows B (I thought was an R) a bunch of space and then N.Y. Also it has a 21 on the tail and on the horn side of the foot it has two 8.s (not pictured)
I also got a 198lb Soderfors. The guy I went to had just taken it in on a 400plus pounder that I really wanted. It has less ring than the first one I mentioned, but has a lot better spring. It rings good, just not as good at the other one. It also has a nice top and the edges are pretty good. The only issue is someone cut off the tip of the horn. Looks like to do some special stuff becuase it has a little dimple in the top of the horn right behind where it is cut off.
The thrid one I bought it was painted solid silver and knew it was European style. Took a shot that it was a Peter Wright and it was once I stripped off the paint. I got this one (0-3-18) 102lbs becuase I can move it around and work it over if I want. Question on this one. Being soild Wrought Iron, did they harden the surfaces on this one? I would like to mill it a little to bring the faces back a little, but I do not want to ruin it. I paid a little over $2 a pound for these but I think they are good anvils. I will choose between the two lager ones once I get my forge setup and sell the other or trade it and something for a lager anvil. I want the 400 plus anvil to sit next to my forge an NEVER move !!!
