Quote
How far forward did you go with the tip?
The tip was a little more than .5 inch from the end of the slot, which was as far forward as I can go with the nipple that's currently in place.
Robert Simmons, on 12 August 2010 - 11:25 PM, said:
From my experimentation I am pretty sure that it is the lack of the constriction that is your problem You want the gas to be blown into a conical constriction. This would take advantage of the venturi principal and speed up the gas flowing through the tube into the burner. Right now your mix is taking place early and the burn is taking place immediately on the end of the supplied mix. So your flame front velocity exceeds your gas velocity and that means it will burn back until it runs out of air to mix with which is justi n front of your injector.
You will need to have the gas get injected before a restriction and then you can asdjust how far from the constriction. You can accomplish this as I did with a reducing pipe or you can use castable refractory and two cones to cast the venturi right into the burner.
I do believe that you're correct regarding gas velocity. I came to the same conclusion last night.
I cleaned up the tube (the interior was ROUGH... like 50 grit sandpaper) and cleared out the jet a bit (a small bur inside.) Still the same basic behavior. Then I removed the flare... the gas stayed outside the tube for a couple of seconds that time then..... WHOMP, the flame popped back up the tube.
So, I'm left with fuel/gas speed being insufficient to push the burn outside the tube.
How to accomodate that? Here's what I'd come up with:
1) Smaller diameter tip. The
M. Porter book lists 2 sizes for a 1" tube. I had chosen the bigger size (45) as it was available locally, but the bigger size means lower velocity. The other size (35?) would give a faster jet of propane, which would also pull in more air. It's hard to read, anyone make it out better or have personal experiance in size choices?
14T-35 Tweco Contact Tips (1140-1302)Tapered .035" contact tip for all Tweco® #2, #3, #4 style guns.
14T-40 Tweco Contact Tips (1140-1303)Tapered .040" contact tip for all Tweco® #2, #3, #4 style guns.
14T-45 Tweco Contact Tips (1140-1304)Tapered .045" contact tip for all Tweco® #2, #3, #4 style guns.
2) Bigger slots. If the slots aren't allowing the jet to pull air in as easily as it would like, then the suction that results would be a drag on the air that does go down the pipe, causing the velocity to be slow.
3) There is an implication in the M. Porter book that the 1/8" pipe nipple is an "accelerator." That you want this to be as long and unrestricted as possible so that the pressure will accellerate the propane to maximum speed before it gets constricted and ejected from the tip. I blew off this observation, noting that the original reil burners, with an effective length of 0 worked. Still, maybe something to it. My pipe nipple is 2", though I've got another 2" or so in various adapers before that... they may not count.
http://www.abana.org...bteaser_mig.pdf
Quote
the most important section for acceleration is the last few inches
of the accelerator assembly. The pressurized gas is also gaining
momentum in the pipe portion of the accelerator assembly. It
takes between three and four inches of pipe length for the gas to
reach full velocity before it encounters the contact tip. A short
pipe on the accelerator will ruin burner performance (the
advanced accelerator is a partial exception to the rule).
4) One other bit of info I gleaned from the Amazon version of the book is that square slots function better (less drag) than rounded slot ends, so that's another easy-to-test thing.
You suggestion about the cone really speaks to #2, essentially. Easier airflow. Ultimately, no more air is going to go through the tube than a given amount of suction/venturi/speed can pull into the burner tube. The cone is mainly about more air draw surface as far as I can tell.
I'd seen a reference to a venturi insert once, but would need to research more before going that route to see if it's even possible to retrofit in this burner. Basically just put the venturi at the end of the tube (instead-of/in-addition-to the flare?) so that the flame can't come back inside due to the speed at the point of contriction?
Does anyone have any comments about 1 or 3, specifically? Comments about 2 are welcome too.
