Castolyte Pouring Twice?
6 replies to this topic
#1 Robert Simmons
    Senior Member
  • Members
  • 160 posts
  • LocationBroomfield, CO
Posted 29 July 2010 - 05:36 AM
Greetings,
I am casting my first forge with castolyte in a 30 gallon drum that i have converted to a forge. I made all the forms and prepared the castolyte and to my horror I found that i didnt have enough castolyte to finish the job. I can run to the store tomorrow but what i am wondering is if I can pour new castolyte on top of already dry castolyte and still have a good bond between the two pours.
Thanks
#2 welder19
    Senior Member
  • Members
  • 910 posts
  • LocationNJ Pinebarrens
Posted 29 July 2010 - 07:06 AM
More than likely it should be ok, just leave the surface rough where the second pour would contact the first, even jagged and uneven as well.
welder19
It's better to be hated for who you are than to be loved for who you are not
#3 Phil Krankowski
    Member
  • Members
  • 4,142 posts
  • LocationOhio
Posted 29 July 2010 - 08:51 AM
Could scratch it with some wire like old school plaster and lath was done for the base coats.
Phil
Your brain is the most powerful tool you own.
#4 monstermetal
    Senior Member
  • Members
  • 1,818 posts
Posted 29 July 2010 - 10:06 AM
I can tell you what I would do... that is drill some small holes in the set side and put some inconel wire in there to span the seam... kind of like rebar...
My great concern is not whether you have failed, but whether you are content with your failure.
Abraham Lincoln
#5 Nakedanvil - Grant Sarver
    The Ferrous of them All!
  • Members
  • 3,124 posts
  • LocationRight here at OCP Galactic Headquarters!
Posted 29 July 2010 - 01:44 PM
It's just a forge! Not the Taj Mahal. Wham, bam, thank you Ma'm! 30 gallon! Wow, you can make a pretty good forge in a 5 gallon bucket!
There is no other answer unless you want to knock it out and start over.
“There are painters who transform the sun into a yellow spot,
but then there are others who, with the help of their art and their intelligence,
transform a yellow spot into the sun.” ~ Pablo Picasso ~
#6 Robert Simmons
    Senior Member
  • Members
  • 160 posts
Posted 29 July 2010 - 01:58 PM
View PostNakedanvil - Grant Sarver, on 29 July 2010 - 01:44 PM, said:
It's just a forge! Not the Taj Mahal. Wham, bam, thank you Mam! 30 gallon! Wow, you can make a pretty good forge in a 5 gallon bucket!
I trimmed off the bottom and top 4 inches or so, leaving the ribbed section in the middle for rigidity and to hold the castolyte in place. I will post a photo when done. The work area of the forge is essentially a 9" diameter circle that has been squared up on the bottom to make an arch providing a 9" floor for hard bricks if I want. The length is 18" and there is enough for three burners and a ceramic blanket inside if I want less volume and more heat. All of the inlet pipes for the burners are cast with a half an inch flare so I dont have to use flares in the forge. The roof and side walls are 4.5 inch thick castolyte.
Should be pretty impressive in heat. I think I might just use insulated fire brick for the doors though.
#7 chyancarrek
    Senior Member
  • Members
  • 915 posts
  • LocationNext to Mt St Helens
Posted 29 July 2010 - 11:53 PM
Larry and Grant are on it - just put a little something in there to bind it all together and go for the second round - I've done it a number of times on casting furnaces - some times it's a little slap-dash but it'll hold heat and do what ya want.
Just Grind To The Intent
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
