Hammers
49 replies to this topic
#1 brianbrazealblacksmith
    Senior Member
  • Members
  • 1,163 posts
  • LocationMississippi
Posted 18 July 2010 - 08:59 AM
Here's some hammers Lyle, LDW, and I forged yesterday, 2 rounding hammers and 2 fullering hammers. Lyle gets his pick of the fullering hammers and the other will go to rapula in Columbia for 3 mini anvils that we traded while he was in the states working with my brother. The big rounding hammer is mine. The smaller one goes to "Tim the toolman" from Mississippi. Tim traded a 20 pound set hammer in brand new shape while we were at Fire in the Swamp last month for a hammer, and we finally got around to forging it. I still have to grind, heat treat, and handle them.
Attached File  P7180002.jpg   206.63K   483 downloads
#2 clinton
    Ironmonger
  • Members
  • 1,143 posts
  • LocationSalinas, California USA
Posted 18 July 2010 - 09:14 AM
Those look great Brian. What is the weight of the big one?
I think that I must have bumped my head
#3 brianbrazealblacksmith
    Senior Member
  • Members
  • 1,163 posts
Posted 18 July 2010 - 09:27 AM
I don't know, Clinton, I don't have a scale, but Lyle just showed up and said "let's go get a scale". I guess we're going to get a scale. We'll be back in a bit.
#4 brianbrazealblacksmith
    Senior Member
  • Members
  • 1,163 posts
Posted 18 July 2010 - 11:02 AM
We are back. The big hammer weighs 4 pounds 11 ounces. It started as 4 1/2 inches of 2 1/4 inch round 1045 which weighed 5 pounds, so we lost 5 ounces to scale minus the plug which weighed .15 ounces.
#5 rapula
    Member
  • Members
  • PipPip
  • 12 posts
  • LocationColombia, South America
Posted 18 July 2010 - 12:33 PM
Nice hammers Brian, looking forward to working with one of those. I will not come to the states again till next year but, maybe you come down to see me before that time??...
#6 clinton
    Ironmonger
  • Members
  • 1,143 posts
Posted 18 July 2010 - 12:34 PM
wow that is big indeed, so the other hammers are in the 3 1/2 lb range?
#7 Danger Dillon
    Member
  • Members
  • 919 posts
  • LocationAtlanta area
Posted 18 July 2010 - 01:25 PM
Excellent work Brian, I'm always amazed and I especially love the touch mark that puts your hammers in a class of their own.
Michael Dillon
#8 brianbrazealblacksmith
    Senior Member
  • Members
  • 1,163 posts
Posted 18 July 2010 - 02:57 PM
Thanks, guys!
Clinton, the other hammers weigh 3 pounds 4 ounces, 3 pounds 5.5 ounces, and the small one which is out of 1 3/4 inch round weighs 2 1/2 pounds.
rapula, I'd love to come to South America, but I don't leave home unless I have work and can afford to. If you give me your address, I'll mail it to you.
#9 longhunter
    Senior Member
  • Members
  • 115 posts
  • LocationPennsylvania
Posted 20 July 2010 - 07:12 PM
Nice hammers Brian always enjoy seeing your work !
Member of the BGCM
#10 brianbrazealblacksmith
    Senior Member
  • Members
  • 1,163 posts
Posted 21 July 2010 - 02:58 PM
Here are the finished hammers.Attached File  P7210003.jpg   223.9K   282 downloads
#11 jimbob
    Senior Member
  • Members
  • 968 posts
Posted 23 July 2010 - 07:12 AM
how do you temper the the fullering hammers
James R. Davis
If everything seems to be going well, you have obviously overlooked something.
#12 brianbrazealblacksmith
    Senior Member
  • Members
  • 1,163 posts
Posted 23 July 2010 - 07:28 AM
I temper them by heating my drifts up and putting them in the hammer eye alternating sides each time. The middle of the hammer will show blue, and the faces straw after about three drifts.
#13 brianbrazealblacksmith
    Senior Member
  • Members
  • 1,163 posts
Posted 23 July 2010 - 07:55 AM
I found this old post and Lyle helped me paste it here.
http://www.iforgeiro...g-with-a-drift/
#14 ofafeather
    Member
  • Members
  • 271 posts
  • LocationAncramdale, NY- Where NY, MA and CT come together
Posted 23 July 2010 - 08:21 AM
Hi, Brian. Those are fantastic looking hammers! Thanks for sharing. Being somewhat new to this I am having a hard time figuring out the difference between the rounding and fullering hammers. Which is which and when would you choose one over the other? I am thinking that a rounding hammer has a round domed face and is used for dishing? A fullering hammer would be more like a peen? Sorry, a little confused. Great hammers, though!
Also, seems like the hammer would work well with those using Hofi's method in terms of balance of the head and type of handle. Is that the case?
Thanks!
Eric
#15 brianbrazealblacksmith
    Senior Member
  • Members
  • 1,163 posts
Posted 23 July 2010 - 09:36 AM
Thanks!
Eric
Hey, Eric. The rounding hammer has the ball fuller, and the fullering hammer has the straight fuller. I use a hand hammer for most of my work, and different sized fullers or peens are my choices of dies to use. The rounding hammer has the largest selection of different sized fullers availiable, and the degree at which I tilt it determines the size of fuller I choose, since the ball end is not a true half sphere. The center of the ball has about a 4" radius, and when tilted the radius changes all the way to under 1/2" radius. I can also hit smaller spots with the rounding hammer.
The fullering hammer has a 3" radius all the way across, and that is my most common choice of die for drawing and isolating material with half hammer faced blows over the edges of the anvil. The rounding hammer works like a true fuller on smaller stock, but when I am striking across 1" or more I need to switch to the fullering hammer.
The cross peen hammer is not as versitile as the rounding and fullering hammer because all it has is a flat face and a straight fuller of a given size. I have that on my flat face when I tilt it or not. I do use a cross peen when making things like calla lilies, spatulas, and shovels where I am doing an extreme lateral draw.
Anyone can shape their handles to what they prefer. I personally prefer my handles rectangular all the way. Most of my work is done by tilting my hammer to some degree, and the flat sides of the handle make this easy to control.
#16 ofafeather
    Member
  • Members
  • 271 posts
Posted 23 July 2010 - 03:01 PM
Brian, Thanks for the great explanation. It's pretty amazing what you can accomplish with the rounding hammer! Thanks again.
#17 jimbob
    Senior Member
  • Members
  • 968 posts
Posted 25 July 2010 - 09:00 AM
what about the striking end of the fullering hammer...seems to me it should be softer so as not to chip when hit with another hammer
James R. Davis
#18 Fosterob
    Senior Member
  • Members
  • 668 posts
Posted 25 July 2010 - 09:10 AM
A hammer is not a top tool even though they look similar and and have handles. Hammers should not be struck with other hammers. I think what Brian was saying is his hammers have a fuller on them instead of a cross peen and he explained the difference and how he uses them.
Rob
#19 ofafeather
    Member
  • Members
  • 271 posts
From what I gather this hammer can be used to make fullers, kind of like pein on a cross-pein hammer. It's not actually a handled top-tool meant to be struck. That's just my impression, though.
#20 bigfootnampa
    Senior Member
  • Members
  • 1,071 posts
Posted 25 July 2010 - 09:53 AM
Brian has such accuracy with his hammers that he tends to use them as top tools and strikes with his swing... that's what he is trying to say. He is NOT using them as traditional top tools struck with another hammer. Looking at his work it should be obvious that the man has outstanding if not astonishing hammer control! Even my own hammer accuracy amazes me and it's nowhere NEAR Brian's level. People have some incredible physical potentials! The AVERAGE human being has stunning hand/eye control... I would suggest that Brian is pretty far from average! At least as applicable to smithing skills.
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
