Jason M Posted July 3, 2010 Share Posted July 3, 2010 This a my new treadle hammer that I designed over a year ago and finally welded up recently. It's a straight line linkage type. The hammer weighs about 100 lbs and has a little over 16" of stroke. Link to comment Share on other sites More sharing options...
frank.F Posted July 3, 2010 Share Posted July 3, 2010 This a my new treadle hammer that I designed over a year ago and finally welded up recently. It's a straight line linkage type. The hammer weighs about 100 lbs and has a little over 16" of stroke. your hammer looks VERY NICE!! GOOD JOB! Link to comment Share on other sites More sharing options...
RLD Posted July 3, 2010 Share Posted July 3, 2010 nice looking hammer . I would like to see more of the linking system. Link to comment Share on other sites More sharing options...
rlarkin Posted July 3, 2010 Share Posted July 3, 2010 Hey, isn't he required by LAW to post the working drawings. I thought I saw that somewhere in the posting rules. THAT IS SLICK! I understand the basic mechanics. What I would like to see is how the head is kept stable. I know the angle of the dangle part, but what stabilizes the head? Is it just the bushings in the arms, or is there something I can't see? Link to comment Share on other sites More sharing options...
clinton Posted July 3, 2010 Share Posted July 3, 2010 That looks real slick, can we see what happens when you forge something with it? I am curious as to how the linkage performs under a load, great looking build Link to comment Share on other sites More sharing options...
Jason M Posted July 4, 2010 Author Share Posted July 4, 2010 Thanks for the comments. The linkage itself is its own guide. The pivoting connections keep the hammer inline front to back. The arms riding along themselves inside the frame attachment keep the hammer from moving side to side. I'll try and post another video of it in use when time permits. Link to comment Share on other sites More sharing options...
monstermetal Posted July 4, 2010 Share Posted July 4, 2010 Beautiful job.... If it works as good as it looks you may have just set the new bar for treadle hammers.... Link to comment Share on other sites More sharing options...
pkrankow Posted July 4, 2010 Share Posted July 4, 2010 2 (identical?) parallelogram linkages, (mirrored?) tied together with a slide where the linkages overlap looks to be the trick. One slide is on the ram, attached to the frame, and the other is behind the frame floating "free" to do all the movement. That is extra slick. I think I may have to make a paperboard model later this week. Strange thing is that for raising the bar, it looks relatively simple to build...no complex arrangements and bushing pivots are easy to build. The only thing I don't see are safety cables running though the springs. They may be well hidden inside the springs though. Phil Link to comment Share on other sites More sharing options...
Jason M Posted July 6, 2010 Author Share Posted July 6, 2010 It was very easy to build. Even though there are many linkage bars they can all be done accurately using a drill press. I originally had a solid guide welded to the ram. After the initial assembly I decided to mill a slot and through bolt that part of the frame. If I were to build another one I would just weld two separate bars with a space between them so that no milling would be required. At the moment I have not yet installed the safety cables because I am still working on the spring mounts. I had no knowledge of how many springs I would need. I started with two, then ran back to the store and bought two more. After getting everything put together and lubricated it became real easy to operate the hammer. I was able to reduce the tension on the springs making it real easy to operate.The current mount at the bottom extends past my original "envelope". When I designed the hammer I wanted to make it as compact as possible. The base plate is 30" deep by 28" wide. I offset the main post so that when the plate was up against the wall the mechanism would clear. I am looking into possibly rotating the bottom mount 90° because it stick out 2" past the "envelope". I also am going to add a spring or cushion to the top somewhere to halt the hammer on the upstroke. Under normal operation the weight of my leg is plenty to halt the travel but sometimes it hits at the top if I let it. I'm going to make some dies for it hopefully next week. I'm on vacation this week relaxing. I was experimenting the other day and was able to easily punch through some 11 ga. steel with a center punch and also cut that piece in half using a chisel both while cold. I later went in the house and asked the wife if she could hear me out there. She said yeah but it wasn't any louder than when the train goes by or shake the house any more, almost the same. Jason Link to comment Share on other sites More sharing options...
pkrankow Posted July 6, 2010 Share Posted July 6, 2010 Rubber doorstops? Urethane would be better, maybe a roller blade wheel and adjustable...but really, KISS is sometimes best. Phil Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted July 6, 2010 Share Posted July 6, 2010 My Dad used a couple of V8 valve springs for his bump stops. Thee rubber bump stops over the rear axle of a truck would be a good choice also. Link to comment Share on other sites More sharing options...
Feukair Posted July 6, 2010 Share Posted July 6, 2010 Amazing man! Link to comment Share on other sites More sharing options...
jmeineke Posted July 6, 2010 Share Posted July 6, 2010 Very, very nice. I want one! Link to comment Share on other sites More sharing options...
Marc Posted July 6, 2010 Share Posted July 6, 2010 I used hockey pucks for my bumper stops. Really slick design, by the way. Reminds me of the Grasshopper, but less complicated. Link to comment Share on other sites More sharing options...
Jason M Posted July 7, 2010 Author Share Posted July 7, 2010 Thanks for the input on the bumpers. I do have plenty of springs lying around including valve spring and was thinking of going that route. I do like the axle bumper idea. I'm gonna have to investigate that more. I don't need much of a bumper. Just something quieter than metal on metal. I will keep it simple. I just want to make it look like was meant to be there rather than an after thought which it was. I've seen two versions of a grasshopper. One where you can clearly see the linkages and the other where it was obstructed. It's definitely an effective linkage but I wanted to make something different and more compact. Jasonhttp://www.youtube.com/watch?v=U5xnneil99Q Link to comment Share on other sites More sharing options...
hay budden 202 Posted December 27, 2011 Share Posted December 27, 2011 could u supply measurements? i have bought plans for 2 other kinds of treadle hammers and have seen other designs but this blows them all out of the water. thanks for posting Link to comment Share on other sites More sharing options...
FieryFurnace Posted December 28, 2011 Share Posted December 28, 2011 You should seriously work out any kinks you see and start selling plans. Great hammer! I'm wondering if this hammer is smooth enough for cold, chasing and repousse work? What type of springs did you use in the back? Diameter of coil? Diameter of steel? Length? Source? Once again,GREAT hammer! Link to comment Share on other sites More sharing options...
GregH Posted April 7, 2012 Share Posted April 7, 2012 Now that is xxxxxx fine where about could one acquire a few more specifics on the straight line linkage set up you used? I' am having to make a portable treadle that can be deployed of the back of a trailer and this set up would be perfect. ie the simplest and least complex. Regards GregH Link to comment Share on other sites More sharing options...
aditya Posted April 7, 2012 Share Posted April 7, 2012 Very sleek looking hammer....thanks for sharing. Link to comment Share on other sites More sharing options...
John Larson Posted April 7, 2012 Share Posted April 7, 2012 The hammer linkage and the hammer's operation are very sweet, indeed. FWIW, I saw an historic pump linkage of this sort, nearly identical, on a water pump in the museum of the Tuckahoe Steam Museum near Easton, MD. I took pictures (that are now hard to locate) with intentions of building a treadle hammer using the ideas. Now you've saved me the trouble of reverse engineering. I can steal your ideas directly. :-) Thanks in advance. :-)) Link to comment Share on other sites More sharing options...
John Larson Posted May 13, 2012 Share Posted May 13, 2012 I continue to think about this hammer. I agree with Monster Metal that you've set a standard. Link to comment Share on other sites More sharing options...
mudbugone Posted May 13, 2012 Share Posted May 13, 2012 It's a great hammer design ,but you guys do see this original posting is from 2010 ? I even tried to contact the original poster thru the YouTube video comments without success.Don't know if something happened to him or not ,but he seems to have vanished from the internet which is a shame. I thought he might resurface at some point and offer up drawings or plans for sale,but that hasn't happened either.Too bad...like the rest of you it looks like a top notch design ,but I fear it may be lost since the trail has grown cold for some reason.. Link to comment Share on other sites More sharing options...
CHPerdue Posted May 14, 2012 Share Posted May 14, 2012 Hi Here is how a strait line mech works. You can transfer the idea to a TH. It just takes a little figuring is all :D CH Link to comment Share on other sites More sharing options...
mudbugone Posted May 14, 2012 Share Posted May 14, 2012 The videos aren't that clear because the linkages & the hammer are all in black. It's an interesting discussion though... Similar linkage,but in a vertical pattern instead of horizontal for a clearer understanding of the motion. Do you think this is the linkage design being used on the hammer in question ?http://www.youtube.com/watch?v=5y0rcmESxcY&feature=related Link to comment Share on other sites More sharing options...
mudbugone Posted May 14, 2012 Share Posted May 14, 2012 I went back and viewed the videos again several times and paused them and tried to superimpose the straight line linkage into the design .. I can't do it... while similar in some ways there is a great deal more going on in the linkages of the hammer design than in the simple Roberts design. It's as if the design was doubled somehow with movement front and rear that keeps the hammer head aligned. If anyone sees this differently Please respond with some insight on it. Link to comment Share on other sites More sharing options...
Please sign in to comment
