BIGGUNDOCTOR Posted October 7, 2010 Share Posted October 7, 2010 When we put the workshop in at my folks place my Dad, and his friend did all of the conduit, wiring, panels, etc. The inspector came out, looked it over, and signed the permit off. The final 3 wire hookup to the subpanel was done by an electrician we knew. All work was done to, or better than what the code required; extra clamps, bigger wire, etc. I know that some people will skimp due to the price-especially now, and that can lead to problems. Also not getting the proper information needed to do the job correctly. In Maddog's case I don't know if it would need to be redone, but maybe just inspected to make sure it was done correctly, and have a permit drawn. Quote Link to comment Share on other sites More sharing options...
godijr Posted January 28, 2012 Share Posted January 28, 2012 Any one find a manual for this model Solar 295 amp ac model 110-081 Quote Link to comment Share on other sites More sharing options...
pkrankow Posted January 28, 2012 Share Posted January 28, 2012 http://www.centurytool.net/Solar_Welding_Cutting_Battery_Charger_Manuals_s/32770.htm $8 from the mfg. Phil Quote Link to comment Share on other sites More sharing options...
godijr Posted January 28, 2012 Share Posted January 28, 2012 Phil Sorry they don't list 110-081 Godi Jr. Quote Link to comment Share on other sites More sharing options...
totintools1 Posted March 18, 2012 Share Posted March 18, 2012 If you want to make your own cables for the machine you own-you can use a 4 gauge or larger cable with ground clamps and electrode that you can purchase anywhere. However the plugs you need (the male jacks that plug into the machine) are 3/8" jacks that I believe are only made for Century. At least I haven't found any place else to purchase them. You can purchase the part number 239-052-908 Welding Jack Set from our website at www.welder-pros.com The direct link is http://welder-pros.com/century_and_lincoln_parts_and_accessories.html As to your question about which you cable you lengthen would be better-with your machine it probably does not matter significantly since you do not have a high frequency attachment. However if you coil up the cables, you tend to lose efficiency. Therefore it is usually better to lengthen your 230 volt cable, if you can conveniently move the machine closer to your welding project. Any other questions? Let me know. Thanks,Mont Howard Howard Equipment and Supply 1424 N. Hwy. 91 Shelley, ID 83274 Office 208-357-3200 Cell 208-251-2123www.welder-pros.com Quote Link to comment Share on other sites More sharing options...
