I think I got this at a good price - yes/no? I will start a search for some cables, but wanted to know if those can be home made and if it is okay to make'm longer than normal? And what is normal - 10' or 25'?? Any help will be appreciated - photos below. Oh yeah, gotta get to a class to learn how to use this thing
Century Welder
#1
Posted 13 June 2010 - 04:47 PM
Played by Other Lives,
Tuned by Changing Needs,
With an Audience of One.
T. D. McCoy'82
#2
Posted 13 June 2010 - 05:18 PM
keep searching CL I have seen some leads for sale for around $1-$2 a foot used. Yes, leads can be made long, and that is preferred to adding an extension cord to the welder. I have seen leads up to 100'. As a matter of fact I may have some kicking around. I will have to dig through the pile,might even have the stinger, and ground clamp. I have plenty of helmets, so don't buy one.
I've called the last couple of times I was in Vegas, but got your voice mail. We are going to have to set up a weekend where I can swing by, and give ya some schoolin' on that thingamajig. I think I brought down my copy of the Lincoln Welding text book from when I went through the junior college program, if so I can let you borrow it.
A golf course is a terrible waste of a rifle range.
#3
Posted 13 June 2010 - 05:48 PM
T. D. McCoy'82
#4
Posted 13 June 2010 - 07:34 PM
Phil
#5
Posted 14 June 2010 - 02:50 PM
I've had a Century machine for a zillion years. More basic machine than the nice one you bought. Has been bullet proof...
#6
Posted 14 June 2010 - 09:27 PM
can ya drag the welder a 100+ feet? Much easier to drag the leads.
Ken.
#7
Posted 15 June 2010 - 01:10 AM
Tim
T. D. McCoy'82
#8
Posted 15 June 2010 - 09:19 PM
The 250 amp esab mig runs on 50 amps. That is wide open.
Ken
#9
Posted 16 June 2010 - 10:19 PM
http://www.google.co...0CBsQ8wIwBTgA#p
#10
Posted 17 June 2010 - 12:03 AM
Found a source for Century Welder parts, etc. at http://www.Welder-Pros.com I have an e-mail out to them to find out if I can get a manual or parts list. More later
T. D. McCoy'82
#11
Posted 19 June 2010 - 07:13 PM
Had really good info about welding problems and how to hook up 220 service ... that site had 363 members and 2582 visitors on it today ... gotta love the net!!
T. D. McCoy'82
#12
Posted 19 June 2010 - 07:59 PM
You can also look at the way your range is wired if you have an electric range that is and or a clothes dryer too. It's all the same. 220 is 220
http://weldingweb.co...php/t-9681.html
#13
Posted 20 June 2010 - 10:29 PM
Have to disagree with 220 is 220. My tig/stick miller Will Not run on a dryer service. It takes a 100 amp line. MyHere's a rather good page for what you are looking for. Just remember if you are going to have a long cord on your welder you may need bigger wire from the breaker box to the outlet. What you should do is contact an electrician in your area to find out how the wire size you need for the distance you are going to run your wire to. If you are going to need say 50 feet you will need bigger wire to hold the current. I'm no electrician but, I do know some about it. I know enough to wire 220. Odds are if you go to a store that sells mostly electrical supplies they will be able to tell you just what you need.
http://weldingweb.com/archive/index.php/t-9681.html
mig takes a 50 amp line. Also is it single or 3 phase power. Best to talk to a sparky. Had a big box guy tell me I could run the miller on 16ga wire. If ya don't know what you are doing get help. Working with 1 in sq buss lines 460
volt will make a beliver of you.
Ken.
#14
Posted 21 June 2010 - 11:55 AM
Questions from a non-welder. I found a Century 220 volt 295 amp arc welder at a yard sale sans the leads for $50.00, I bought it. I have seen many arc welders on sale lately and it seems that everyone is still very proud of their equipment and asking "too much". I did a quick search on the net and can't seem to find much info about this particular unit... one guy says that Lincoln bought Century. The box is in very good shape externally, almost new, few scrapes and no dents and the places where the din plugs on the cables plug in are clean and straight. Works AC/DC and has a cutting/hole burning feature - yippie!
Tim: I have the same welder, tho mine is the Cetury 250 Amp AC-DC output. Yours is a 295 amp AC only output.
you have 2 AC ranges- LOW & HIGH The LOW range has more arc volts for small rods, and hard to run AC rods like Low hydrogen 7018, stainless and hard surfacing. High range is for all dia 6011,6013/7014/7024 rods.
They were made in the 1980's, and yours looks to be in beautiful shape, used very little. They are very tough welders that give long touble free service. Base on how expensive new welders are today, YOU GOT A GREAT DEAL!. You will need a to wire it for 240Volt-60 amp [min] input. Mine will trip off a 50 amp breaker, if I weld over 145 amps. I had to install a 60 amp breaker to weld up to 225-250 amp. It will pop that if you weld more than the duty cycle of the welder[2mins, out of 10mins] Also, you need to use a #6 input wire size. Do not go over 30ft [both welding cables] use #2 welding cable[too long will cause voltage drop = hard arc staring.
Always lengthen the input power cable, not the output welding cables on Transformer type welders.
Blacksmith Enthusiast since 2008 "know just enough to be dangerous"
My videos at http://www.youtube.com/user/alpho52
#15
Posted 21 June 2010 - 11:36 PM
Alfonso: I have a model 110-081 Century stick welder220 volt 295 amp AC only unit. Found out mine was made prior to 1982. I appreciate your comments about this unit. Gotta buy some cable now and stinger and connectors ... located a wiring diagram and a parts list ... let me know if you would like copies. Got my infor from:
... can hardly wait to get the 220 installed and get to welding
Yippie!
Tim
T. D. McCoy'82
#16
Posted 25 September 2010 - 11:09 PM
Thanks,
Mont Howard
www.Welder-Pros.com
E-mail: [email protected]
#17
Posted 29 September 2010 - 12:58 AM
#18
Posted 29 September 2010 - 08:27 AM
The lower the voltage, the larger the conductor has to be to push the same amount of power through a line. Which is why power transmission lines run at extremely high voltages. And, of course, the longer the run, the thicker the conductor has to be to supply the same current. Welding cables run low voltages and huge currents. They are heavy thick and expensive. It's much cheaper to put a long power cord on a welder than it is to buy long leads. But welders are heavy and clumsy, even small ones like yours. Even on a cart, do you want to be pulling it around the shop every time you need to weld?
The best is probably a compromise. 25' Welding leads, #1 gauge will probably reach every where in your shop. On the day that you need to weld under a trailer out in the street or set up a swing set in the back yard, you can make up a 220v extension cord and drag the welder out to the job. And like someone says, the gauge will depend on the length of the run.
I have 25' #1 cables on my Idealarc 300, with quick connects on the end so that I can snap in another 25' extension if I need. (the Idealarc weighs 800lbs so rolling out into the driveway is not an option). When I bought the cable, #1 is about $2/ft, I got red and black leads. I would like to make the first 25' out of 1/0 gauge. That will have to wait till I have made my fortune in blacksmithing.
The stinger lead is 3ft of #4 which snaps into the quick connect on the end of the heavy red cable. This makes it easier to manipulate the rod and a few ft of small gauge doesnt have much effect at regular rod sizes. I have a variety of different ground clamps which I can snap onto the quick connect on the end of the black cable. I also have a quick connect lead attached to my welding table.
#19
Posted 01 October 2010 - 01:00 AM
Thanks for the input ... Meancoyote was kind enough to front me 62' of 1/0 cable for the Century welder along with a bag of other goodies for work I will help him with once the Vegas weather stays below 100. Thanks Meancoyote!!! I made a 25' stinger lead and a 20' work lead ... had to buy 2 Lenco hp-10 connectors, a stinger, and now the unit sets under a welding table that I have cobbled together. I will seldom need to move the welder as most of any work that I will do will be small projects. Just waiting for my next allowance issue from the spousal unit to get the 220 installed in the garage. Yes the welder is heavy ... like everything else I have gathered together to learn to be a blacksmith.
Next project is to install a $2 amp selector switch rod, a new power cord and stinger on a Lincoln AC/DC 225 that I picked up for $20
T. D. McCoy'82
#20
Posted 01 October 2010 - 06:00 PM
220V is the name plate minimum voltage for the welder, not what is available from the home service. Also since voltage drop is always a factor, no one can tell you what size wire to run with out knowing the distance or other factors effecting this voltage drop to your service receptacle.
If you want to trust the guy making $8 a hour at the box store, rather than a electrician, fine. Don't forget the building permit for a new install. Home owner Insurance companies dont normally pay for damages from a home owner doing un-licensed installs. Be careful
http://fenrisforge.com
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
