reconditioning a forge
3 replies to this topic
#1 Kendrick
    Member
  • Members
  • PipPipPip
  • 79 posts
Posted 03 June 2010 - 09:43 AM
I got lucky and picked up a rivet forge with a Champion blower for $60 recently. The forge pan is a bit bent up and all the bolts need replaced but all in all it's sound. The blower turned stiff and squalled when moved. I poured tool oil in it until it was running out the seams and cranked it slowly for a couple of minutes. Now it is going smooth and quiet and blows like a champ. However, before I crank away on it, is there anything else I should do to the blower to ensure longevity?
Also, it is dangerously side heavy towards the blower. I have already had it go over a couple of times and luckily nothing broke. For now it's stored on its side. I have thought of clamping weights to the legs opposite the blower. Any other ideas?
Thanks,
Kendrick
#2 John B
    Senior Member
  • Members
  • 2,040 posts
  • LocationStarcross, Devon, UK
Posted 03 June 2010 - 10:56 AM
Attach a bracket and leg to take the weight of the blower at the rear (if you don't want to bolt it to the floor)
#3 Rob Browne
    Senior Member
  • Members
  • 1,320 posts
  • LocationBlue Mtns, NSW, Australia
Posted 03 June 2010 - 05:30 PM
Rearrange the legs so one is under the blower side. Before really using the blower pull it apart and give it a real good clean then you will know what you have.
Rob Browne
Remember, if you have never failed, you have never tried.
#4 CurlyGeorge
    Senior Moment Member
  • Members
  • 2,037 posts
  • LocationFindlay, ILLINOIS/East Central Illinois
Posted 03 June 2010 - 06:57 PM
Hey Jeremy. Glad to hear that you found a rivet forge. Price sounds fair. Get it cleaned up and running for the hammer-in in July. Sure hope you can make it up for that one. Talk with you later. :D
George Spallinger
If it can't be fixed with a big hammer, it's an electrical problem!!....(Author unknown)
Change is inevitable...............Except from a vending machine!!!!
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
