where to buy coal or coke
#1
Posted 08 May 2010 - 11:38 AM
#2
Posted 08 May 2010 - 02:44 PM
Isolate, Distribute, Finish- Toby Hickman
Endeavor to Persevere!
http://www.ironwood-design.net
#3
Posted 08 May 2010 - 03:28 PM
If you want to pay way to much ther is always this
http://cgi.ebay.com/...6#ht_500wt_1182
Delivered, $35 for 25#....There are other things to burn for less bought more local. Lump charcoal, corn, propane.
Phil
#4
Posted 08 May 2010 - 05:55 PM
Phil
Never heard of burning Phil, can you get it to weld temp?
#5
Posted 08 May 2010 - 10:09 PM
But buying charcoal can get a little expensive; I suggest you learn how to make it. Free scrap wood is pretty easy to come by.
#6
Posted 09 May 2010 - 05:03 PM
When I don't have that on hand, I use charcoal I make for myself or I've gleaned from the woodburning stove.
ron
#7
Posted 09 May 2010 - 08:57 PM
Burning Phil is when the unwise Phil forges in shorts on a beautiful spring day and gets hot scale in the top of his boots! Welding only occurs when the unwise Phil forgets that his neck is protected by neither his shirt nor his helmet and fires up the stick welder and does more than glue a few small pieces together with a couple of tack welds causing severe "sunburn" in a smiley shape around his collar.
Phil - not an efficient forge fuel.
#8
Posted 09 May 2010 - 10:07 PM
#9
Posted 09 May 2010 - 10:50 PM
Cheers
Remember, if you have never failed, you have never tried.
#10
Posted 09 May 2010 - 11:10 PM
Thnks all, I didn't know that charcoal could reach forge welding temp.
Real charcoal, though, not that briquette garbage.
#11
Posted 09 May 2010 - 11:39 PM
So in which, part of Nebraska are you located?
Keith
#12
Posted 10 May 2010 - 11:22 AM
So all the migration and viking era pattern welded blades were forgewelded in charcoal and japanese blades are *still* forge welded using charcoal by traditional makers.
Charcoal was used for smelting iron from ore up until the 1700's when Abraham Darby figured a way to use coke for smelting---but "charcoal iron" was considered superior and you can read 19th century blacksmithing references about using "swedish iron" or "charcoal iron" for items needing the highest quality materials.
Now we are not referring to that "modern" abomination called the Charcoal briquette which is engineered to have as little real charcoal in it as possible and to burn slowly for cooking. Shoot I'd rather make charcoal from cow patties and use that over briquettes!
#13
Posted 10 May 2010 - 06:24 PM
#14
Posted 10 May 2010 - 06:46 PM
- Pablo Picasso
#15
Posted 10 May 2010 - 06:53 PM
If you don't mean briquettes, what is the other type of charcoal, the original? I'm a bit confused on this subject as I've never heard of anything but briquette charcoal. I have searched for the answers for this, but they don't seem to be very forthcoming.
Lump charcoal, it is easiest to get at restaurant supply place. Gordon Food Service, GFS, stock lump charcoal year round. Cowboy brand is very common. The lumps are irregular, and rather lightweight compared to briquettes. It is natural charcoal that is broken and bagged without any further processing.
Making it is not too hard, but required fuel wood, space, and understanding neighbors.
Phil
#16
Posted 10 May 2010 - 09:51 PM
Charred wood, i.e., wood with all the volatiles burnt out in the absence of oxygen. It's light, hard, dry, black, makes a tinkling sound when the pieces rattle around -- and it looks like pieces of wood! It's mostly carbon with minimal impurities. You can get it at Lowes or Home Depot, although you'd be better off buying bulk from someplace like GFS, as Phil suggested. Here's a quick rundown on lump vs. briquettes.
#17
Posted 24 June 2010 - 04:50 AM
#18
Posted 24 June 2010 - 07:27 AM
Charcoal was the fuel of blacksmiths for about 2000 years before they started adding coal, (high-late middle ages); but charcoal continued to be used for smithing up until this very minute as you can pretty much make charcoal *anywhere* and good coal is hard to find/get.
[/quote]
Slightly off topic, but charcoal was used for forging even before the iron age, (1200BC ish) Meteorites were being forged into tools used when mummifying Pharoahs.
I was fortunate enough to be asked to produce a replica of one for a student of Egyptology, from a Jupeterian meteorite (only had the chemical analysis to prove that, I could not find a Made on Jupiter mark anywhere on it, but then I don't recognise the language or writing from there), and the one being replicated had been dated as 4000 years old.
The guys daughter produced a short video of when I made it and it was on the web at one time under the title Forging the Bear.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
