side draft question
7 replies to this topic
#1 ledson
    Member
  • Members
  • PipPip
  • 22 posts
  • LocationHants County, Nova Scotia
Posted 27 April 2010 - 04:59 PM
Someone is giving me 15 feet of pipe, 15 inch in diameter. My question is could I make a side draft hood out of it then have the remainder to be the vertical pipe off it? my fire pot is 12in by 12in.
#2 steve sells
    Old Curmudgeon
  • Members
  • 2,076 posts
  • LocationFt Wayne IN, USA
Posted 27 April 2010 - 10:20 PM
of course.
#3 RoryMay
    Member
  • Members
  • 221 posts
  • Locationpine, CO
Posted 27 April 2010 - 10:51 PM
only on days that end with "y"
Blacksmith / digital super hero
♠ www.dragonforgeltd.com ♠ www.rorymay.com ♠
#4 ledson
    Member
  • Members
  • PipPip
  • 22 posts
Posted 28 April 2010 - 05:17 AM
Like this wonderful skitch I have attached?
reason being is I don't want to put a hole through the roof if I didn't have to, so if cutting the pipe and joining them in this fashion would work, then that's what I'll do.
#5 ledson
    Member
  • Members
  • PipPip
  • 22 posts
Posted 29 April 2010 - 05:30 AM
The rough sketch is what I meant, I see square box type at the fire pot through the wall with the round pipe attached vertically so I'm not sure if I'm wasting my time using the round pipe at my fire pot then run it vertically off it.
I don't want to put a hole through the roof if I didn't have to, so if cutting the pipe in two sections and putting if through the side of the shop would work, then that's what I'll do.
I still have the 55 gallon barrel and if using it as my hood and then run my 15in pipe straight up off it through the roof would work better, then I'll do that. I need to know which way would work the best because I screwed it up the first time and I do not want to get smoked out again.
#6 Phil Krankowski
    Member
  • Members
  • 4,143 posts
  • LocationOhio
Posted 29 April 2010 - 07:44 AM
Your sketch looks like Hofi's setup from the missing blueprints. Maybe Glenn will make the blueprint(s) in question available for you to look at for a day or so.
Phil
Your brain is the most powerful tool you own.
#7 jayco
    Senior Member
  • Members
  • 795 posts
Posted 29 April 2010 - 10:30 AM
Hi Ledson,
My sidedraft is loosely based on Hofi's design, and very much like your drawing as well.
I'm well satisfied with how mine performs.
Hofi's side drafts are really nice, while mine was built from what scrap I had available.
It still works GOOD.
There are a bunch of pictures in my gallery showing how mine is made.
Good luck, James
There is no time lost in MEASURING!
#8 minifarmer
    Junior Member
  • Members
  • Pip
  • 7 posts
Posted 01 June 2010 - 10:36 PM
I'm using the Hofi syle side draft . I have never had a problem. It draws very well,I never have any smoke inside the shop,it's very simple.
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
