Anvil / hammer safety
#1
Posted 12 March 2010 - 02:37 AM
Occationaly, once in a while, I miss the red target with my 3# cross pien and hit the anvil, which causes the hammer to rebound at great velocity toward my face. So far I have controlled it in time, and not whacked myself, but it catches me by suprise every time I do it, and I dread the day I react too slow and make the connection. I use a mild steel, homemade anvil, knuckle height, and was wondering if a real anvil responds that way with such dramatic rebound, or if there's other bad habits this may be indicative of.
#2
Posted 12 March 2010 - 03:15 AM
Isolate, Distribute, Finish- Toby Hickman
Endeavor to Persevere!
http://www.ironwood-design.net
#3
Posted 12 March 2010 - 08:52 AM
Check you stance, If you get a rebound, it should go over your shoulder, not to your head, Just turn away slightly,
Try to watch an experienced 'smith, but don't concentrate on what they are hitting, look at their position relative to the anvil,their stance, spread of the feet, the arm and wrist action, the grip, how they control the blows, the type of blows, their general attitude
Try different methods incorporating what you have seen, and assess how it works for you, then develop your own style
#4
Posted 12 March 2010 - 10:29 AM
If it can't be fixed with a big hammer, it's an electrical problem!!....(Author unknown)
Change is inevitable...............Except from a vending machine!!!!
#5
Posted 12 March 2010 - 10:35 AM
#6
Posted 12 March 2010 - 12:57 PM
#7
Posted 12 March 2010 - 01:16 PM
And a hardened face anvil is *much* worse in the rebound department---it will send it back faster and higher!
#8
Posted 12 March 2010 - 02:33 PM
*Nadasecond, somewhere between instantaneous and too small to measure. The time it takes for a hammer missing the metal and hitting the anvil to travel the distance between the anvil and your forehead. In many cases a nadasecond is less then the reaction time of the fellow holding the hammer, resulting in the hammer hitting him in the head.
Proper anvil height is confirmed by putting a piece of wood on the anvil face and observing the hammer marks. Crescent at 12 o'clock means the anvil is too low, crescent at 6 o'clock means the anvil is too high, crescents at 3 and 9 o'clock mean the anvil is not level or the hammer is held at an angle.
Stand at the anvil with the hammer resting on the target point of the work. Now move to one side or the other until the shoulder, elbow, wrist, and hammer (hammer handle and hammer head) are all in one plane (straight line). The rebound of the hammer will follow this straight line when it launches from the anvil. Notice that your head is not in this line of travel, your vision is not blocked by the hammer, and you can actually see when and where the hammer strikes the metal.
Another reference about planting cross peens in foreheads can be found here.
#9
Posted 12 March 2010 - 08:31 PM
ThomasPowers, on 12 March 2010 - 01:16 PM, said:
One theme I'm hearing though too, is body position relative to the anvil. Should the hammer fall on the anvil directly in front of my belt buckle, or directly in front of the hip (or where the hand would be if it was hanging limp from my shoulder)?
Edit: Ok, read further on the subject and I'm thinking I get it. Thanks guys
#10
Posted 12 March 2010 - 09:04 PM
First is called the plane of rotation and why you should stay out of them. The streak of mud on a bicyclist's back is a perfect example, the mud being slung off the tire will fly outwards in the plane of rotation. A hammer rebounding off an anvil from a missed blow will travel in the plane of rotation defined by your swing. This is why you should learn to swing the hammer out of line with your head!
As has been said, a hardened anvil will impart greater rebound energy to the hammer making it faster and more dangerous.
You're encountering what happens when you add power to a system. The more power in a system the more critical and the more difficult control become. For a gross example consider a golf cart, about 4-5HP and no problem controlling it at all. Right? Compare it to a good old fashioned hopped up muscle car sporting about 500 ponies, keeping THAT under control can be a serious challenge. No?
So, those are the reasons to slow down, use a lighter hammer and practice till you have good control. I'm just now regaining some of my former control at the anvil as I recover from the brain injuries I survived last September. Happily I'm getting em back faster than I deserve but I'm still not as good as I was just a few months ago.
In response to your last question. NO! Never lock your elbow, wrist or any other body part in contact with a hammer on an anvil! Do NOT make any part of your anatomy absorb the impact. Hole the hammer is a loose grip, just tight enough it doesn't fly off on it's own. (See plane of rotation above!)I use what I call a "fencer's grip" on my hammers, holding the slab handles between my thumb and index(?) finger. The hammer pivots in my hand till just before impact when I give my fist a quick brief clench bringing the handle and hammer into a more common position with my hand. This does a couple things: First it greatly increases the power in my blows by adding a 4th joint, each joint in your arm, and hand is a force multiplier so adding one multiplies the energy you put into the hammer. The second is the loose grip does NOT transmit impact energies back into my hand and saves me fatigue and injuries.
Frosty the Lucky.
Inside a dog it's too dark to read.
"Groucho Marx"
#11
Posted 12 March 2010 - 09:15 PM
No, you don't want your arm to be trying to hold down the hammer at the end of the blow. You never want any body part absorbing the energy, you want to transfer all energy into the work and make your life as easy as possible. You are describing the wrong kind of striking. Stricking in the manner in which you describe is similar to how a nail is hammered into wood. There is no rebound and the wood absorbs the shock. However, in forgework, You have to stay loose. Your hammer weighs enough to cause tendon and ligament problems if you are fighting it. You have to allow the hammer to rebound with a steady rythm. Muscles are used to bring the hammer down and very little effort is required to pick it back up if any. And as you are in a rythm, when you want harder hits, make them harder or bring it up further before your down stroke. The steel that you are forging absorbs most of the rebound.
In the case of a mis-hit and a huge rebound. Your arm and hammer should fly back up just as you describe, but the hammer and your arm should not be coming anywhere close to your head or face, unless what you are doing is sighting over your hammer as if it where a gun, which is a no no. Your hammer comes back up to the same point where it started from, so don't start from in front of your face.
You should have the ability to fix improper posture quickly, and develop a feel for where the hammer is. It should become an extension of your body and the face of the hammer should become more accurate than Bruce Li's fist. In which case you are not paying attention to body movement, but only to where you want to touch the hammer face on your work.$
#12
Posted 12 March 2010 - 09:33 PM
Ed Steinkirchner
-Plato-
#13
Posted 12 March 2010 - 11:08 PM
#14
Posted 13 March 2010 - 01:25 AM
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
