Show me your mechanical hammer fly wheel break
#1
Posted 10 March 2010 - 08:58 PM
brad
#2
Posted 10 March 2010 - 10:16 PM
but then there are others who, with the help of their art and their intelligence,
transform a yellow spot into the sun.” ~ Pablo Picasso ~
#3
Posted 10 March 2010 - 11:26 PM
#4
Posted 11 March 2010 - 01:09 AM
Nakedanvil - Grant Sarver, on 10 March 2010 - 10:16 PM, said:
oops did I say break ??? well I meant brake ... sorry.
brad
#5
Posted 11 March 2010 - 01:26 AM
I have to apologize to you. I was cursing the unknown buyer of the hammer I was going to see the next day. I didn't expect to join IFI and find the culprit! I have been moping around the shop dreaming of the lost hammer, my wife told me "to suck it up buttercup" Wait until I tell her you already have a 50 lb LG. You are in big trouble mister. Just kidding around and hope you got a good deal on it.
Erick
#6
Posted 11 March 2010 - 11:40 AM
DSCN3002.JPG 196.53K
136 downloads
DSCN3005.JPG 167K
125 downloadsHere is mine 75lb commonsense hammer it is attached to the side of the control arm and it just rubs on the flange of the drive pulley, very simple design and it works good
Hey Grant don't "Freak Out" on the brain police dude just go chill in joes garage, may be some catholic girls over there
I think that I must have bumped my head
#7
Posted 11 March 2010 - 12:10 PM
Extend the arm that engages the clutch until it is under the center of the flywheel. Weld a short section of pipe to the end vertically. Make a brake shoe that closely matches the curve of the flywheel. Line this with leather, brake shoe material or belting, using glue and/or rivets.
Fabricate a bracket with a pivot on the back side of the shoe to hold a short section of threaded rod that fits closely in the pipe section on the arm.
Put a nut on the threaded rod, drop the brake shoe and threaded rod into the vertical pipe and and put another nut on the bottom. Use these to adjust the brake shoe up and down in relationship to fly wheel.
The hammer and clutch should be adjusted to work as designed, with the brake out of the way. Adjust the brake shoe up towards the flywheel so it engages when the clutch disengages when you ease off on the treadle.
A small adjustable spring from the top of the brake arm to to one of the top bearing bolts helps with the action ,as well as some kind of simple slotted guide for the arm.
The flywheel must turn into the brake shoe to work properly. Grind or file any casting irregularities off of the flywheel. Keep the flywheel clean of oil and grease.
I know pictures would be helpful, but try it as described. Most of the linkage is already there and the fact that inboard [ towards the operator ] end of the clutch arm goes up when the clutch is disengages allows for a pretty simple and elegant solution.
Like I said , a 25# hammer doesn't need a very large brake to work, the one n my 25# LG is about 8" long.
This type of brake should work on the smaller size hammers, but does not have enough engagement for 100# and up hammers.
#8
Posted 12 March 2010 - 04:43 PM
#9
Posted 12 March 2010 - 07:57 PM
Mike
#10
Posted 12 March 2010 - 09:37 PM
The flywheel appears to be tappered very slightly; maybe a casting irregularity. Do you think that it should be machined as I have a lathe.
brad
#11
Posted 13 March 2010 - 01:16 AM
I think the flywheel on mine is very slightly tapered as well. I would just form the brake shoe to fit. Getting rid of any bumps on the casting will make the action smoother.
If you had the flywheel and shaft off the machine as part of the rebuild you could turn it true, but I don't think that is really needed unless there are gross irregularities in the casting
#12
Posted 14 March 2010 - 03:34 AM
I was thinking of making an adapter for a scooter disk brake and disk, to be mounted on the far end of the hammer shaft. It hasn't got to the top of the list yet - anyone done something similar?
#13
Posted 15 March 2010 - 11:22 PM
When I was first interested in a brake I though of using a master cylinder from a car so if you go this route I would like to hear about it.
brad.
#14
Posted 15 March 2010 - 11:50 PM
Boy that thing is a tank! never seen a hammer like that!
Abraham Lincoln
#15
Posted 16 March 2010 - 09:10 AM
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
