Forge Materials for a Canadian Noob-Smith
#1
Posted 25 February 2010 - 03:55 PM
first time poster here.
I'm located in Winnpeg, Manitoba (about 3 hours North from Grand Forks ND, and I'm trying to get materials for this forge: http://home.flash.ne...forge/plan1.pdf
Question 1: Did I pick a silly design, considering I want a blower forge?
Question 2: Where can I find Kaowool (or equivalent), ITC-100 (or equiv) and firebricks for the bottom and door? I can't seem to find any shops in Winnipeg that sells that stuff.
Question 3: I've seen a lot of pictures of people using expired freon containers and the like- would an expired propane container do the trick?
Thanks guys!
A craftsman is happiest when he delivers a flawless piece,
A hobby blacksmith is happiest when making the tools for whatever project he's decided to try this time!
#2
Posted 25 February 2010 - 04:45 PM
#3
Posted 25 February 2010 - 06:29 PM
I just finished building a new forge, so should be able to help you out i hope...
for almost all the stuff you want except the steel and ITC 100 you can get from The sounding stone pottery place. http://www.soundings...&categoryId=143
half way down the page is the blacket and bricks you'll want. For ITC 100 I had to get it shipped from the states, after shipping and taxes it ended up costing alot but made a big difference.
The shell of my forge is a old propane tank off a truck and works fine. If you need a propane regulator and hose I went to welder's supply.
Good luck
-Mike
#4
Posted 26 February 2010 - 11:07 AM
Thanks guys!
This forge http://home.flash.ne...forge/plan1.pdf is a good design but seems a little over powered; I built a scaled down version of it with a 6" dia x 14" long fire chamber in a 10 " shell cut from a length of a discarded nitrogen bottle. Same as the model but 4" shorter. I used a the same refractory mortar I used over the ceramic wool (Inswool; the "other kaywool"
As for finding materials locally, is there a furnace or boiler maker in your area? Ask where they get their refractories. They may even have scrap enough for your project. Otherwise, mail order is a very doable alternative in about any area. Hope this helps
Semper Fi! Its not just for breakfast anymore!!
#5
Posted 26 February 2010 - 11:47 AM
JNewman- I completely hadn't thought of the Mercaptan! Do you think firing it once at low temp without insulation would do the trick? For getting the dregs of propane out, my plan was to fill it with water twice. I"d then cut the top off with an angle grinder.
Lenaghan- Cheers, mate! Do you think I'd be able to take a look at your forge (I'll send a PM)? the Sounding Stone looks to have good inventory, I'll check it out this weekend. Do you think I'd be able to use their kiln wash or hi-temp cement to surface the ceramic wool (the fiberfrax, right?)?
Dodge- Good to know I picked a good design
Also, what size of blower should I get? I was thinking of just cannibalizing a hairdryer and using a blade valve for more precise control...
Thanks again!
#6
Posted 26 February 2010 - 08:37 PM
Toreus, on 26 February 2010 - 11:47 AM, said:
Dodge- ... BTW, is the front plate (door?) on your forge held on by the two bolts at the top and the pivot at the bottom? Is it sheet-metal and ceramic wool insert construction?
Thanks again!
Hmmm, sheetmetal! Wish I'd thought of that. Would've made construction easier LOL Actually its just an angle iron frame and the exposed wool is coated with mortar. It hangs with two hooks on loops at the top and a pin through loops secures it to the bottom. Front and rear door are identical. Sorry, no help on the blower. I just found one in a pile of salvage parts and it worked. I do in deed use a blade valve. Hard to mess up simple
#7
Posted 28 February 2010 - 03:10 AM
#8
Posted 14 March 2010 - 12:56 AM
I've finally gotten the time to clean up the propane tank cylinder.
I let all of the propane out, twisted the valve off with a long wrench, filled it with water and then took an angle grinder to it.
I plan to make a base out of 1/8 x 1 galvanized stock and then bolt it on before putting in the ceramic wool. [1] Are there any problems with having holes UNDER the insulation? (I'm thinking the galvanized is far enough so it wouldn't burn.)
The shell I have left is 12in deep and has a 12in diameter. Assuming 2 layers of 1in wool, this would leave me with an inside area of (10-2)*pi*((12-2*2)/2)^2= 402 cubic inches. To start with I would have a door made of soft firebricks, eventually replaced by a door made with the cut off from the tank and attached the same way as Dodge's door.
I seem to remember people quoting numbers like 350in^3 per burner, but I think those were all for venturi burners. [2]Should I keep one big burner as planned, or move to two small/medium ones? Could I temporarily fill the unwanted space with soft firebricks (low thermal mass)? I'd like to be able to achieve welding temp, even if it's just for the small space that wouldn't be filled with firebricks.
[3] Have you guys needed to completely open both ends of your forge? I'm thinking of just making a small 2in x 3in opening at the back, plugged with a firebrick when not in use, but I'm not sure if it would be large enough...
Thanks for all your help,
T.
PS: The mercaptan smell isn't actually that bad. Wouldn't want it next to my pillow, but with 2in of refractory I won't even be able to smell it. Maybe because I flushed it with water then wirebrushed the dickens out of it?
#9
Posted 30 May 2010 - 02:56 PM
Hey guys!
Got the forge body welded up, and I did a fire test yesterday to make sure everything was working. Now I'm just waiting for a dry day so I can install the refractory and get it curing.
P1010066.JPG 1.8MB
57 downloads
P1010064.JPG 644.49K
54 downloadsI still haven't fine-tuned the mixture, but I want the refractory in before I do that.
More detailed pictures:
P1010072.JPG 1.35MB
38 downloads
P1010067.JPG 1.74MB
30 downloads
P1010088.JPG 1.3MB
23 downloadsThe flamestop is a foot-long piece of .25in flat bar cold-twisted about 300*. (I love overly large pipe wrenches
P1010079.JPG 1.92MB
23 downloads
P1010074.JPG 1.77MB
17 downloadsI'm really happy with how the doors came out- they're very easy to put on, even one-handed. I will put large wingnuts on to make it feasible when the forge is running full blast.
P1010081.JPG 1.93MB
17 downloadsSucker heated fast! I had it on for about 50-60s and after it cooled, I noticed these lovely oxidation colours.
Thanks to everyone, a more helpful group of people would be very hard to find!
And lastly- does anyone have any comments/suggestions for this forge?
Cheers,
T.
#10
Posted 30 May 2010 - 03:17 PM
JNewman, on 25 February 2010 - 04:45 PM, said:
#11
Posted 30 May 2010 - 03:51 PM
Glenn, on 30 May 2010 - 03:17 PM, said:
I didn't use flame at all- I opened the valve and put the tank upside down to vent any remaining gas, then I unscrewed the valve. I filled the closed container with water to the top to ensure there was nothing left. I then used an angle grinder to remove the front and bottom, which have now become the front and back.
If you guys can think of any other steps/processes to make it safer, I'd be glad to hear them!
T.
#12
Posted 30 May 2010 - 06:00 PM
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
