forge questions, how to?
17 replies to this topic
#1 Thurstan
    Member
  • Members
  • PipPip
  • 12 posts
Posted 23 February 2010 - 03:08 PM
Hi, every1 this is my first post and i am new to blacksmithing. Now i got myself a anvil and some hammers + thongs, but i can't find a good fire. So i decided to build 1 myself.
I havent been able to get my hands on a brake drum, but i have been able to get 50kg of fire mortar that can hold temp's till 1100° c .
So my question is, does any1 here on the forum have a good id on how to use this fire mortar to make me a good forge? I want to start practice on some knifes and afterwards some art.
Got alot of old files and springsteel to practice on.
Ive made me a card with wheels, i was thinking about maybe putting on a iron box on top of that with a 20 cm high border and try to make the fire pot out of the fire mortar.
What do you guys think about that and will the fire mortar hold up for it?
greetings from belgium
#2 Nakedanvil - Grant Sarver
    The Ferrous of them All!
  • Members
  • 3,124 posts
  • LocationRight here at OCP Galactic Headquarters!
Posted 23 February 2010 - 03:46 PM
Be sure and post pictures of you forging in your "thongs"! ROFLMAO
Sounds like you got a good start, go for it!
“There are painters who transform the sun into a yellow spot,
but then there are others who, with the help of their art and their intelligence,
transform a yellow spot into the sun.” ~ Pablo Picasso ~
#3 NRunals
    Member
  • Members
  • 128 posts
  • LocationMichigan
Posted 23 February 2010 - 04:02 PM
make sure your forging thongs are leather for protection!
#4 fat pete
    Senior Member
  • Members
  • 791 posts
Posted 23 February 2010 - 04:04 PM
I agree i wanna see the thongs...lol ....i have a hard enough time making tongs, i could see me making a thong....ha
but as to you question...if you search around the site you will find tons of pics of different configurations of all kinds of forges some are simple some are not...some guys have made them outta bar b que grills...some guys use a dirt pit...55 gal drums make nice ones...as far as the mortor goes I think it will not be durable enough...if you would get a couple of bricks you may be able to fashion something to get you a good fire...remember with a little air you can run 18-2200 degrees F plus, so I am not sure 1100c degree stuff (2050 degrees) will hold up since you are at your limit...where there is a will there is a way..
#5 Thurstan
    Member
  • Members
  • PipPip
  • 12 posts
Posted 23 February 2010 - 04:42 PM
lol ok, srry that my english isn't all that well...
At the moment the only thing i can get a hold of is the fire mortor, If i try to use it for the forge, do you think it will explode or simply crack when it gets to warm?
problem with the bricks over here is that they are made for bbq's and arent all that good. I just want to get started with forging, even if the mortar only holds for a couple of months.
#6 Nakedanvil - Grant Sarver
  • Members
  • 3,124 posts
Posted 23 February 2010 - 05:30 PM
Should work fine, most of the heat is going up. Even if your mortar vitrifies it will still do it's job.
Devrait fonctionner correctement, la plupart de la chaleur monte. Même si votre mortier vitrifie il faudra encore le faire son travail.
DénudéEnclume
#7 Thurstan
    Member
  • Members
  • PipPip
  • 12 posts
Posted 24 February 2010 - 04:54 AM
Ok thx alot for the constructive advice. I will start on it today :)
Btw nakedanvil, thx for the french, but my main language is dutch :)
#8 Bad Creek Blacksmith
    Senior Member
  • Members
  • 332 posts
  • LocationNorthwest Ohio
Posted 24 February 2010 - 05:57 AM
Glen posted let's see your forge under the solid fuel forge forum there should be some good pictures of home forges...my firepot is made out of 3/8" plate steel and lined on the bottom only with refactory cement. Good luck!!!
P.S. If you don't find anything there look under show me your shop in the general blacksmithing forum.
It's okay to make a mistake, just as long as you learn from it.
#9 Thurstan
    Member
  • Members
  • PipPip
  • 12 posts
Posted 24 February 2010 - 07:43 AM
I have found some very good examples on that topic. I'm busy making the forge at this moment, I'm hoping to get the mortar in by tonight. I will also try to post some pictures.
#10 Thurstan
    Member
  • Members
  • PipPip
  • 12 posts
Posted 25 February 2010 - 11:15 AM
I have just finished putting in the mortar. Still have some left for adjustments.
Here are some pictures. What do you guys think?
#11 ThomasPowers
    Senior Moment Member; Master Curmudgeon
  • Members
  • 10,183 posts
  • LocationCentral NM
Posted 25 February 2010 - 12:23 PM
Remind me again will you be using coal or charcoal for the fuel?
Thomas Psychotic Psychobabblonian Powers
#12 Thurstan
    Member
  • Members
  • PipPip
  • 12 posts
Posted 25 February 2010 - 12:38 PM
Well I have alot of wood stored atm (poplar and birch). So I am thinking about making my own charcoal and use that for fuel.
Why the question?
#13 Rob Browne
    Senior Member
  • Members
  • 1,320 posts
  • LocationBlue Mtns, NSW, Australia
Posted 28 February 2010 - 12:05 AM
Why the question?
Thomas is probably looking at getting the depth in your fire you need. With coal its easy as it will not burn too fast around the "edge" of the fire, a bit of water and its contained. With charcoal, however, you need a deep fire but just staking the charcoal around the fire to build its depth will result in all your charcoal burning, it just burns and you can't really stop it. So I would say that is a nice setup for coal but not for charcoal. For charcoal you need deep sides to allow you to put in the minimum fuel to get your fire depth without burning excess fuel.
Cheers
Rob Browne
Remember, if you have never failed, you have never tried.
#14 Phil Krankowski
    Member
  • Members
  • 4,142 posts
  • LocationOhio
Posted 28 February 2010 - 07:06 PM
Cheers
Mention has been made time and again of using brick stood alongside the fire pot to help make the fire deeper as a way to use a forge designed for coal or coke with wood charcoal. I think this is called a "duck nest" by some people, but could be wrong.
Phil
Your brain is the most powerful tool you own.
#15 ThomasPowers
  • Members
  • 10,183 posts
Posted 01 March 2010 - 12:34 PM
Exactly If I was going to use that firepot for charcoal I would stack some firebricks in it on the sides to make it deep and narrow.
#16 Thurstan
    Member
  • Members
  • PipPip
  • 12 posts
Posted 03 March 2010 - 04:33 AM
ah, i was gonna ask what was the best fuel. I tried the forge yesterday with charcoal and it burns up rather fast. But i do have a large stockpile ( about 3 cubical ) of coal. it used to be from my grandparents. So i think i will try to use that for fuel. Thanks for the advice :)
#17 ThomasPowers
  • Members
  • 10,183 posts
Posted 03 March 2010 - 11:27 AM
Charcoal is a fuel where you DON'T want an electric blower, it takes a lot less air than coal and doesn't tend to go out on it's own.
So a hand crank or bellows is a good way to go.
If you have to use an electric blower, put a foot switch on it so it only runs when you are pressing on the switch, and be sure you can cut down on the air being delivered to the tuyere as well. It will save you a lot of fuel and steel!
#18 Pat Roy
    Member
  • Members
  • 285 posts
  • LocationMid Coast Maine
Posted 06 March 2010 - 07:08 PM
For 4 or 5 years I've been using a firepot I made from 3/8" plain steel plate without brick or refractory. It show no sign of deterioration in any way. If I ever burn it out, I will fabricate another. I got the idea from Randy McDaniel's book.
I thought I had made a mistake once, but I was wrong.
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
