Hunter3 Posted December 13, 2009 Share Posted December 13, 2009 At what pressure does everyone run their regulator on a propane forge? Link to comment Share on other sites More sharing options...
Judson Yaggy Posted December 13, 2009 Share Posted December 13, 2009 Atmospheric (venturi type) or blown? I run my 2 venturi style forges between 4 and 10 psi depending on what I'm doing. I run a 3 burner NC Tool forge and a 2 burner Chile forge. Link to comment Share on other sites More sharing options...
monstermetal Posted December 13, 2009 Share Posted December 13, 2009 Ya know thats not really enough question... My Johnson forge will basically take all the propane you can get out of a 25 gal bottle and it not be enough to run all 4 burners With the regulator maxed out (it reads up to 80 psi) it will never get about 15psi because there is no back pressure... big orifices... big burners very inefficient... Now my 12" round forge with a T Rex Hybrid burner Its all about what I want for heat... I'll run it about 20 psi until it gets up to heat... If I am doing general forging I might back it down in to the 5-10 PSI range.... If I am welding I might crank it up to 25 PSI My two burrner venturi home made forge I run about 15-20 PSI after it is warmed up... It has two 1" burners that have a #60 drill orifice Link to comment Share on other sites More sharing options...
fat pete Posted December 14, 2009 Share Posted December 14, 2009 5-7 on my chilli usually only use 1 burner...run both to bring up to temp...60# lasts about 40 hrs+/- Link to comment Share on other sites More sharing options...
pkrankow Posted December 14, 2009 Share Posted December 14, 2009 (edited) 3-10 psi depending. 2 burner atmospheric. Freezes a 20 lb bottle hard in 1.5 hours, in a tank of water makes a 2 inch rim of ice in 2 hours. Phil As requested orifice size Orifice size .035 contact tips. 3/4 inch Frosty T-burner. Build specifics are here.http://www.iforgeiron.com/forum/f86/i-pumped-frosty-information-made-13160/ Phil Edited December 14, 2009 by pkrankow Link to comment Share on other sites More sharing options...
tech413 Posted December 14, 2009 Share Posted December 14, 2009 I run my single burner atmospheric at 3-6 psi for regular forging, 12-15 for welding. Adam Link to comment Share on other sites More sharing options...
monstermetal Posted December 14, 2009 Share Posted December 14, 2009 Yeah but like I said... those pressure numbers are meaningless without a corresponding orifice size.... 5 PSI with running out the end of an open hose is not the same as 5psi running to a forge with a 1/64 th size orifice One has a CF that equates to a fraction of a gallon per hour... The other a CF that is several gallons per hour.... Just the PSI number, unless you are comparing two identical factory made forges.... doesn't tell you anything Link to comment Share on other sites More sharing options...
ThomasPowers Posted December 14, 2009 Share Posted December 14, 2009 My Sofa Workshop built aspirated forge I generally run close to 10 psi on the gauge I have on it's regulator. HOWEVER I have not calibrated this gauge in years and so it may be +/- 50% as small cheap gauges are notorious for being in accurate. Link to comment Share on other sites More sharing options...
Sukellos Posted December 15, 2009 Share Posted December 15, 2009 I ran my single burner atmospheric up to 22 psi and couldn't get weld heat. What am I doing wrong? Link to comment Share on other sites More sharing options...
pkrankow Posted December 15, 2009 Share Posted December 15, 2009 I ran my single burner atmospheric up to 22 psi and couldn't get weld heat. What am I doing wrong? First what burner and orifice size? Second is it tuned reasonably well? Lean/rich, flame down center of flare... third how well insulated is your forge? 4th how big is the cavity? 5th how about the openings, how big are those? Then we get into procedure: What material(s) are you trying to weld? How long did you soak for, was the forge fully heated up? Oh, and Got pics of your setup? Phil Link to comment Share on other sites More sharing options...
Fe-Wood Posted December 15, 2009 Share Posted December 15, 2009 I run my home made hybrid burner at about 5 psi for general forging out a .035 tip. When running both burners I up it to around 7#. Haven't forge welded in it yet because I'm to lazy to coat it with ITC-100 first. I use coke forge instead. Link to comment Share on other sites More sharing options...
KYBOY Posted December 15, 2009 Share Posted December 15, 2009 For general forging I run my diamondback two burner at about 4-7 psi depending on the steel. Welding I run it from 12-15 psi depending on what Im welding. Link to comment Share on other sites More sharing options...
Sukellos Posted December 16, 2009 Share Posted December 16, 2009 I'm not home right now, but I'll get that info to you Phil. Thanks for offering to help. Link to comment Share on other sites More sharing options...
Sukellos Posted December 16, 2009 Share Posted December 16, 2009 First what burner and orifice size? Second is it tuned reasonably well? Lean/rich, flame down center of flare... third how well insulated is your forge? 4th how big is the cavity? 5th how about the openings, how big are those? Then we get into procedure: What material(s) are you trying to weld? How long did you soak for, was the forge fully heated up? Oh, and Got pics of your setup? Phil It's a commercial unit. Here's a pic. Single burner forge. 3" x 7" x 6-1/2" firebox, With Rear Bar Stock Door with flap cover 3" x 1-1/2" about the same on the front opening. Looks to be 1" Kaowool lining with a firebrick floor. I don't know the orifice size but it's small. Guessing about #60. I'd be happy with a simple folded weld on 1/2 bar stock. Mild steel. Link to comment Share on other sites More sharing options...
pkrankow Posted December 16, 2009 Share Posted December 16, 2009 (edited) It's a commercial unit. Here's a pic. Single burner forge. 3" x 7" x 6-1/2" firebox, With Rear Bar Stock Door with flap cover 3" x 1-1/2" about the same on the front opening. Looks to be 1" Kaowool lining with a firebrick floor. I don't know the orifice size but it's small. Guessing about #60. I'd be happy with a simple folded weld on 1/2 bar stock. Mild steel.I haven't counted the hours on my single burner, atmospheric, forge yet. It will operate at about 6 psi for normal forging. It won't make weld heat at any pressure. A 30# tank will last me a long time. Not much problem with freeze ups. I guess that's because I usually shut down every few minutes to save gas while I stupidly fumble about my shop. Maybe the 110 f weather helps too. Based on your post in this thread: http://www.iforgeiron.com/forum/f86/questions-about-propane-use-16171/ the problem may be procedure, but some propane forges can't weld either, they simply are not built to do so as many tasks never require welding. Contacting the mfg would be the next step to find out if this forge was built to weld or not. With my 2 burner forge, I can forge before it is fully hot on small stuff (1/2 inch or smaller) but for a welding attempt it needs to heat at 7-10 psi for a good 15-30 minutes AND the metal needs to soak for 5-10 minutes, until I can't tell the color of the forge floor from the metal. You should be looking with a tinted welding lens, or at least dark sun glasses. It is uncomfortable (and harmful) to look without tinted eye wear. If your forge is supposed to be able to weld, then heat the forge till it is thoroughly hot first. This can be done at a forging pressure since you want to warm up on some light forging anyways. Crank the pressure up some after it is hot and glowing, put your steel in to soak and give it a try when everything looks "white" hot. Put that bottle in a bucket of water, it will freeze during welding, and potentially reduce your pressure. Cold tap water is fine. You will also suck up a lot more gas than for regular forging. I can only fagot weld so far, but that is not my forges fault. I'm still learning too, and many other people here know a whole lot more than me. Phil PS higher carbon steel welds at a slightly lower temperature. Phil Edited December 16, 2009 by pkrankow Link to comment Share on other sites More sharing options...
horseshoer1983 Posted December 16, 2009 Share Posted December 16, 2009 (edited) i run my nc 2 burner at 4-6psi for modding and shaping keg shoes and 10-15psi for handmades and forge welding barshoes and such. i go thru 2 tanks a week in the mobile rig. everything in the shop is done in the coke. if im praticing for a contest or heating stacks of all 4 shoes ill crank it up to 20psi. repeitive forging i run it a big higher for faster recovery. Edited December 16, 2009 by horseshoer1983 Link to comment Share on other sites More sharing options...
Sukellos Posted December 16, 2009 Share Posted December 16, 2009 PKrankow: Thanks for the suggestions. I fooled around this morning moving the orifice around in the burner tube and it "sounds" better. I didn't try to weld but I forged a dragon head bottle opener for my son, the bartender. From what you've said, maybe my problem is just patience. My wife says I have none. We're about to take off to spend the holidays out of country. I'll try again when I get home. I may have to buy another galvanized tub to put the propane cylinder into with water. Link to comment Share on other sites More sharing options...
Dodge Posted December 17, 2009 Share Posted December 17, 2009 I have a blown 1.25" X 10" tube with a about a .05" orifice. Inside a 6" x 15" chamber blanketed with 2" of Ins-wool and coated with AP Green refractory mortar, I run about 3 - 5 psi for general forging. 8 - 12psi for serious work and general welding. Haven't gone much higher for fear of creating a China Syndrome effect but it gets stupid hot where I believe the lining could melt if run at length. :D Link to comment Share on other sites More sharing options...
RedLeg0811 Posted January 15, 2010 Share Posted January 15, 2010 Get a pyro meter and a K thermocoupler. You can Figure out the exact presure and temp your forge should be. I picked one up a month ago and found I had too high of presure for what I needed and was able to turn it down which will save me gas. Martin Link to comment Share on other sites More sharing options...
Please sign in to comment
