Mankel forge
11 replies to this topic
#1 SoCal Dave
    Junior Member
  • Members
  • 152 posts
  • LocationSimi Valley, Ca
Posted 09 December 2009 - 09:19 PM
Anyone with experience using a Mankel Forge with blower? I was wondering if there was any problems having three sides open. I know you can block of the two ends with bricks, but I was wonder if the forge will get hot enough to forge weld? The open aspect adds versatility to the forge, but without doors I imagine it would take some time to get up to welding temps and use a lot of gas in the process.
#2 Nakedanvil - Grant Sarver
    The Ferrous of them All!
  • Members
  • 3,124 posts
  • LocationRight here at OCP Galactic Headquarters!
Posted 09 December 2009 - 09:44 PM
That type of forge is great for heating horse shoes. That design has been copied way too much by people wanting to do general forging IMHO. With the sides open it would be difficult to impossible to get a welding heat. Even with a blower.
“There are painters who transform the sun into a yellow spot,
but then there are others who, with the help of their art and their intelligence,
transform a yellow spot into the sun.” ~ Pablo Picasso ~
#3 Dragons lair
    Senior Member
  • Members
  • 1,189 posts
  • LocationFairview NC
Posted 09 December 2009 - 10:20 PM
There were 3 of them at school running on methane. We used soft brick to close one end and the long side. Not sure how early they were lit but ran all day at welding heat.
Ken
#4 D Lisch
    Member
  • Members
  • PipPipPip
  • 39 posts
Posted 10 December 2009 - 12:32 AM
I like what Grant said you should close up the holes if you can.
#5 rthibeau
    Senior Member
  • Members
  • 1,090 posts
  • LocationTraverse City, MI
Posted 10 December 2009 - 09:55 AM
I have a Mankel 3 burner with air blower......you can leave it open for larger stuff or close off 1 or 2 or 3 sides depending on what you want to do. I fabbed up a steel insert to close the 2 sides and rear to raise the top section for more room and used fire bricks to close in the front. A very versatile forge. Close it up for forge welding to save gas.
Richard Thibeau, blacksmith and creative metal recycler www.dancingfrogforge.com
#6 Francis Trez Cole
    Senior Member
  • Members
  • 1,087 posts
Posted 10 December 2009 - 10:43 AM
I have a 3 burner mankel it came with plugs to close up the ends I have used fire bricks to plug up the long side. I normaly keep one end open and close off the side once the metal is in I slide in 1/2 of a fire brick so about 90% is closed off. I use my coal for for welding. Have not had the occision to weld in it flux can damage the refractory. I will try it soon It is a great forge its like a little jet engin. The only problems I have had was a mud dabber built a nest in one of the tubes so how I close all it up when done and I redrilled the blower and truned the motor away from the opening it was over heating and shutting down and with the gas on high and no blower it is a dangerous. I have melted copper and brass in a crusable but have to shut bown the blower before removing. I also put values on each burner so I can run one or two at a time. I use about 20 pounds in three hours with all three burners going.
Longfellow:
His brow is wet with honest sweat,
He earns whate'er he can,
And looks the whole world in the face,
For he owes not any man.
#7 Kiwi Pete
    Member
  • Members
  • PipPip
  • 11 posts
  • LocationNew Zealand
Posted 22 February 2010 - 03:43 AM
hi i built a recperative gas forge from ABANA plans some years ago, I can get a good heat but not enough for welding, is it possible to weld with a gas forge.
Irun LPG as propane is not available in NZ. :rolleyes:
#8 ThomasPowers
    Senior Moment Member; Master Curmudgeon
  • Members
  • 10,183 posts
  • LocationCentral NM
Posted 22 February 2010 - 12:41 PM
A whole lot of the top end knifemakers use only gas forges for welding up billets, even at substantial altitudes, 5000+
So yes it's possible. The type of fuel gas used shouldn't matter much if the burner is tuned for it.
Thomas Psychotic Psychobabblonian Powers
#9 Jack Evers
    Member
  • Members
  • 156 posts
Posted 22 February 2010 - 04:15 PM
I have made a forge welded bar shoe on a 9000 foot pass in Clorado. That said, my blower powered Mankle would not weld (I couldn't get the adjustment right) until I replaced the blower with an atmospheric conversion. It is a horseshoer's special plus four from the middle 70's, still in use.
#10 yesteryearforge
    Senior Member
  • Members
  • 1,073 posts
Posted 22 February 2010 - 04:50 PM
I thought LPG ( liquid petroleum gas ) was propane
as opposed to natural gas
Mike
Give out before you give up. If it was easy anybody could do it.
#11 Jack Evers
    Member
  • Members
  • 156 posts
Posted 23 February 2010 - 02:27 AM
Mike
Quote
LPG is a gas that can be liquified by pressure at normal temperatures. Basically propane and butane or some sort of mix. Butane requires lower pressure at a given temperature so is safer in hot areas but will start to fail you at temps near normal room temp (assuming you'd like 10 psi or so supply). Propane is good to temps well below zero, but has very high tank pressures as temps go into the triple digits. Your gas company may vary the mix with the season, but use mostly propane..
#12 Kiwi Pete
    Member
  • Members
  • PipPip
  • 11 posts
Posted 25 February 2010 - 03:34 AM
[quote name='yesteryearforge' date='22 February 2010 - 04:50 PM' timestamp='1266875438' post='160600']
Mike
[Thats correct but over here they mix an blend of Propane and butane , which lowers the calorific value.
I will try adding blower to my next experiment.I intend to blow gas up through ceramic balls to simulate a coal forge thus making it easier to heat odd shapes and eliminating the need for an enclosed box.]
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
