How to finish steel to Look like Bronze?
7 replies to this topic
#1 Roy Bryant
    Junior Member
  • Members
  • Pip
  • 3 posts
Posted 05 November 2009 - 07:40 PM
Anyone know how to finish steel to look like bronze. I am building a fireplace screen that needs to have a antique bronze finish. Any hep would be apreciated.
#2 Cavala
    Junior Member
  • Members
  • 121 posts
  • LocationNashville, Tn
Posted 05 November 2009 - 08:05 PM
They probably mean oil rubbed bronze which can be done in a faux finish layering dark brown and black with bronze highlights, otherwise you should try plating and then darkening that, jax has some good products for all that
#3 Phil Krankowski
    Member
  • Members
  • 4,145 posts
  • LocationOhio
Posted 05 November 2009 - 08:35 PM
Rub with bronze wool at high black heat. This is similar to using a brass brush for brass highlights.
Phil
Your brain is the most powerful tool you own.
#4 Roy Bryant
    Junior Member
  • Members
  • Pip
  • 3 posts
Posted 05 November 2009 - 08:51 PM
I see that bronze wool can be bought in course med and fine grades does one grade work better than others?
#5 Roy Bryant
    Junior Member
  • Members
  • Pip
  • 3 posts
Posted 05 November 2009 - 08:56 PM
Cavala
dark brown , black highlights? Paint? or what type of product? bronze highlights? Paint or other? do you know of referance materal telling how to do this?
#6 Cavala
    Junior Member
  • Members
  • 121 posts
Posted 05 November 2009 - 10:03 PM
The technic I use for a faux finish is coat with a dark brown spray paint let dry then take dark walnut wood stain and dab it on with a dry paint brush to create a mottled look let that dry completly and seal with aclear coat.
Another technic is spraying the piece with a metalic bronze paint and then lightly spray dark brown then black holding the can back so to let the other colors show through.
But just try to google oil rubbed bronze finishes I'm sure you'll find many more ideas
good luck Marc
#7 781
    Senior Member
  • Members
  • 580 posts
  • LocationSouth Central Minnesota
Posted 05 November 2009 - 11:26 PM
Robb Gunter at a recent demo stated he has been using a bronze powder coat he has bee very happy with lately.
Not sure if it would hold up to the heat of a fireplace screen
#8 Phil Krankowski
    Member
  • Members
  • 4,145 posts
  • LocationOhio
Posted 06 November 2009 - 11:55 AM
Dunno about grades, I used a piece of what I had as a trial, and it worked. Can't take pics as I reforged some. I think I have course. I imagine that finer grades would go on faster.
Phil
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
