Show me your anvil
1,111 posts in this topic
Posted · Report post
Most folks have an anvil of sorts. Show me what you use and how it is set up. That way we can er-borrow ideas to use.
Share this post
Link to post
Ok it is a little old, tired and was found in a junk yard. Would you bring it home?
Rest of the story?
French anvil dated 1723. A French rohset on the side, an "MN" Monarchy Napoleon on the other side. Found in a junk yard in the old town of Jaffa.
Share this post
Link to post
sitting on a stand fabricated from heavy plate
84.attach
Share this post
Link to post
I do not have an anvil....I just use one of yesteryearforge's. But I do have some pictures of other people's anvils!
Peyton
2715.attach
2716.attach
2717.attach
Share this post
Link to post
Primtechsmiths workstation in my forge
260 lb JHM competitor
85.attach
Share this post
Link to post
My son Joshs workstation in my forge
400 lb peter wright
86.attach
Share this post
Link to post
My anvil at Dancing Frog Forge, something around 300 lbs.
87.attach
Share this post
Link to post
see attached photo
Anvil and stand - this is the 250lb Peter Wright that I replated and rehardened about 20 years ago. The concrete stand is about 300 lbs so the whole thing is pretty stable. The stain on top is oil from the pump can for the p-hammer. I also have a 100 lb Hay Budden that is my demo anvil on a metal stand.
PS - All this talk about old anvils - I had a Mousehole that appeared to date from the late 1600's, based on Postman's book. It was not in outstanding shape but still plenty serviceable considering the age - I sold it to a fellow smith in this area. Pretty cool to see an old lump of iron still being used.
2718.attach
Share this post
Link to post
My Main Anvil 125 lb Blackjack.
2719.attach
Share this post
Link to post
My 300 lb German hornless anvil. Not as unique as the French anvil, but different anyway. . .
BT
102.attach
Share this post
Link to post
I use two anvils. The one on the three-legged stand is a 160lb Trenton and the one on the wood stand is a 132lb Trenton. I built the wood stand with 4x4 oak from pallets used to ship steel to a local sign making company. The steel stand was made from scrap from a local salvage yard. They both work well.
103.attach
104.attach
Share this post
Link to post
I still don't have a real anvil, but I use a 75 lb piece of I Beam, a good inch think in the web, a little loud if you are out on the wings, so I try and keep the hammering over the center part. 10 lbs of jack hammer bit C clamped to the side as a horn of sorts, another 30 lb block of steel, 3x3x12 inches rests on one of the lower wings.
I keep looking for a real anvil but no luck just yet.
Michael
Share this post
Link to post
Well, Ive finally gotten around to posting the pics I took 3 days ago.
I mounted it to my stump using plumbers tape and lag bolts. One of these days, I am going to loosen it up, and shove a piece of conveyor belting under there, which should take care of the last remnants of the ringing.
111.attach
112.attach
Share this post
Link to post
One more anvil added to the group.
Share this post
Link to post
here is a pic of my new anvil, a 260 JHM Competitor. i am studying the different stands posted here to best decide how to build mine.
thanks, George
122.attach
Share this post
Link to post
Stryder
I build my stands like a three sided box with the opening towards where I stand.
You would be suprised at how much more comfortable it is to stand at an anvil when you can put your leading foot slightly under the anvil.
just as a square stump allows you to stand closer to the anvil than a round stump an opening in the back allows you to stand even closer. the result is less strain on your back and legs as you dont have to be reaching over to hit.
an added benifit is a stand made this way from heavy plate almost allways deadens the ring from your anvil. the photo of primtechsmiths is a 260 competitor like yours
123.attach
124.attach
125.attach
Share this post
Link to post
Not done yet but this was cut from 4" plate. Horn was roughed with a O/A torch the finished with a 7" zircon flap disc. Feet cut separate and will be severely welded ;)
126.attach
Share this post
Link to post
You got the right idea, Michael. If it works, do it! ;) Keep looking tho. I am. And I hear they're out there :)
Share this post
Link to post
I had an anvil stand made from heavy plate and it increased the level of sound in the shop so much I gave it away.
Thomas
Share this post
Link to post
yesteryearforge, that is one fine anvil stand!! thanks for the input. George
Share this post
Link to post
Dodge, that is quite an anvil that you are making. Is the face tool steel?
Share this post
Link to post
I am happy to inform everyone that I finally got my first anvil today at an auction that I was working at for $180. I'm not sure of the weight, but if I had to estimate it, I'd say it's about 150 lb'er. Not a bad deal at all, especially the condition it's in! I'll get my cousin's camera and snap a shot of it and post it this weekend.
Share this post
Link to post
No. Its solid mild steel. Might hard face b4 its all said and done but I've done some banging on it and as long as I maintain good hammer control ;) It is working good. Besides, if I leave it mild I can fix any dents or dings easily with my mig:)
Share this post
Link to post
Why not forge weld a tool steel face on it?
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
