don schad
    82
Profile Information
  • Location
    New Hampshire, USA
Converted
  • Location
    North of Concord, NH
Recent Profile Visitors
4,642 profile views
  1. I'm still tuning mine up, but one thing to check is the fit of the throttle lever linkage into the throttle valve. This should be a square shaft into a square hole. After being used for 80+ years, mine was more like an oval shaft into a square hole. The result was a large degree of motion of the lever before it would engage and turn the throttle valve (i.e. backlash). A few degrees of play in the valve connection could end up being inches in the treadle. I had to build up the corners of the throttle control shaft with welding rod and then file to fit. Also make sure it is lubed and the packing gland is not too tight. Don
  2. My IK does have good control when approaching the dies, but I am frustrated with an overall short stroke due to banging into the cylinder on return. With the adjustable stroke the upper 3rd or so is off limits. I don't think that Ken's kit would help with this (too much stroke for too little cylinder), but if/when I get into reworking everything that was something I was wondering about. The motion/control looks very interesting. Thanks for your comments.
  3. Hi Judson - do you know how many BPM you are getting when your machine is running flat out? I've seen the videos and they typically focus on slow control (which looks super), but not the more rapid blows. Do you think that your tup weight is appropriate for the valving (i.e. not too big)? Also, regarding your comment on the up stroke - is it always banging at the top of the up stroke or is it hitting the top when parking after you let off the treadle? I am considering converting my Iron Kiss to use this system. Thanks, Don
  4. good way to put it... its buddy left 4 yrs ago and no one has even visited it. It gotta go tho his wife is really tired of it. I do not use it because I do not have enough time to. I ended up with a regular job these last 5 yrs and I do not have time for anything. I thought about making a project out of it but I know I would never finish it. I think someone could make a nice working piece out of it with out a whole lot of trouble.
  5. thats all the pics I have....
  6. Sorry I miss read you post
    your looking to buy
    again sorry
    Mark
  7. I've moved away from this machine I think. It isn't 100% clear who the manufacture is, and I don't think I want to get into a project if things go bad. Thanks though.
  8. Hi all, I am considering purchasing an older Anyang 165 two-piece hammer. At present the age of the machine is not known, but it is at least 20+ years old. I have read about some of the older machines having a problem where they get very hot. I don't know if this is a problem which can be fixed or not. But I am also wondering if there are other problems or if people have thoughts on these older machines. Are they comparable to the current crop in terms of reliability and quality? I am also considering purchasing a new 88, but this other machine just came up. Is the control on these older 165s less then on the current 88s? I would love to hear any experiences or thoughts. Thanks for your thoughts, Don
  9. Hi all, Thanks for your replies, this is helpful information. I will be sure to closely examine the arms and rollers, among the other items suggested. I have a 50# LG which I am happy with, and I have been thinking of getting a larger machine to augment it, but I haven't really been looking. Then out of the blue I got a call from some one wondering if I were interested in this hammer, so I figure it can't hurt to look. I also came across a thread in the forums about motor mounting for this type of hammer. I'm not sure what set up this hammer has, although he did say it would require a motor also, so that might be useful also. Again, thanks - your comments are appreciated. Don
  10. Hi all, I am going to look at a non-running 100# Beaudry-Champion - #4 hammer in the near future. I don't know too much at this point, except that the owner hasn't run it either and the sow block is not in good shape/was repaired in some dubious manner. I was wondering if anyone could suggest specific problem areas or things to look for when I inspect it? Anything specific to check or look out for? Areas of wear to be concerned about? How about parts/rebuilding such a machine - I assume there isn't anything available, but can things be reasonably forged/fab/machined? Finally, what would be the value of a well running #4? Based on their reputation I would think better then a similar sized LG? Any thoughts or experience welcome. Thanks, Don
  11. I had a very interesting experience yesterday, which I would like to share. I have a typical routine for starting up the power hammer (LG) which includes wiping down the hammer dies from the oil and scale which builds up over night from dripping out of the ways. My routine was interrupted yesterday, and I hadn't cleaned the dies when I pulled a 2"x 3/16" flat which had some minor cupping in the end out of the fire. I saw the mess, but I didn't want to waste the heat, and I didn't think too much about the messy dies. My intent was to take a couple of gentle hits to make it flat, so I continued and put the piece on the die cup down, and made a firm blow - boom! I was completely surprised to have an explosion occur at impact! It was like someone popped a large balloon, complete with a shower of oil and scale sprayed across the room. It took me a moment to figure out what happened, not relating the explosion to a routine power hammer strike, something that otherwise should have been a crisp wack. In the end I figure that the oil was trapped in the cupped area getting super heated/boiling, when I brought the head down the compression of the cup caused the oil to flash and it blew up. It was one of those times that you know your safety glasses were a good investment. don
  12. I found that I 1 brick seemed most effective for me, but it still required quite a lot of huffing-and-puffing from me. Where are those apprentices when you need them? I definitely agree this is a problem. It looks like the forge might be undersized with respect to the piping, and the location of the bellows and forge make it hard to have some bends on the way. The forge was built in the relocated historical building and the blacksmithing equipment acquired during the construction of the forge back in the 1970's. Unfortunately the forge and bellows were never an active matched set in a working blacksmith shop so it didn't get optimized over time. Hopefully I can get things improved a bit so that more energy can be spent hammering and less pumping. Thanks for all the input. don
  13. Yes, thanks for this suggestion. I did checked and clean out the pathways when I got just the tiniest of puffs with my first pulls of the lever. The equipment was unused for quite a while and it was a bit clogged with coal/ash but I didn't displace any families. Thanks, don
  14. Interesting, what gives them away as modern day bellows? They did look to be in relatively good condition when I treated the leather, with a patch on the back side, but beyond that they looked "old". There are a couple of small leaks, but in my estimation they weren't accounting for the low volume at the firepot. The top and bottom chambers are the same size, although the last person to use them (10+ years ago) had put two bricks on top to restrict the expansion of the top chamber. Thanks for your input! don
