knives
Posted by shane, 15 February 2010 · 4 views
would like an help with knife handles.info on how to use deer horns.ben using wood want somthing different.also would like to know how to build a burner for gas forge.
hey shane just wanted to share how i use antlers for handles
first i use my scroll saw to split bone then i trace tang on one side w/pencil i then use my dremel w/a small end mill to remove material i usually have my holes drilled thru tang already so i then put the blade and the half of the antler in my drill press and drill thru the bone taking care to not let the tang slip around
once i have half my antler drilled i then put the other half on and use a rubber band to keep it together so i can drill the other side out leaving the tang in antler while drilling helps ensure that your holes line up
after doing these steps use rubbing alcohol to clean oils or dirt off tang and antler i use a 5 minute epoxy pretty liberally to help fill any voids in the cavity that was dremeled out and also to help bond scales to tang
lastly i insert my pins thru tang and lightly pein them
i use brass pins as they pein easily
take care to wipe all excess epoxy off as you go cuz the stuff makes a mess and leaves a shine on the bone
this is how i do it but there may be a better way, pretty new to all this myself but have had pretty good luck with the antler
hope this helps and good luck! ;)
scott
oh by the way i forgot to mention how important it is to LIGHTLY pein pins as i cracked the first two handles i attached :angry:
May 2012
S M T W T F S
  12345
6789101112
13141516 17 1819
20212223242526
2728293031
Recent Entries
Recent Comments
Categories
